Posted 07 September 2023 - 11:45 AM
Iโve got. 1991 mini city with a 1380cc with a kent 286 cam.
Is there any reason it shouldnโt pass a mot on emmisons? Iโve been told that it wonโt pass due to the cam by the garage
Thanks Iโm advance
Posted 07 September 2023 - 11:55 AM
The only way to find out is to have it tested.
Is it still on SU carbs ?
If so, you could lean the mixture, which might help a bit
Posted 07 September 2023 - 12:34 PM
yep its got a HIF44 carb on it.
Its been through MOT before with same engine but they are saying laws have changed and it wont pass now.....
Posted 07 September 2023 - 12:54 PM
This is a reason why I don't like A+ blocks.
With removable tappet chest covers, it was only a couple of hours work to change the cam in situ, --- pass the test with a standard cam and swap it back in the evening.
The lumpy idling doesn't help, so you could try getting tick-over up to 2,500 RPM.
Posted 07 September 2023 - 04:40 PM
sounds to me like they want you to take your business somewhere else...
Posted 07 September 2023 - 06:44 PM
Posted 07 September 2023 - 08:58 PM
Your 1991 car may or may not have had a cat, only the manual will know. I'm sure cats were 1992 onwards BUT it can be argued that the engines haven't changed from the 80s sooo they don't need a cat to pass
Edited by cal844, 07 September 2023 - 09:00 PM.
Posted 08 September 2023 - 06:23 PM
Posted 08 September 2023 - 08:46 PM
Posted 08 September 2023 - 09:26 PM
Do any 1275 blocks have tappet covers? My Spridget engine doesn't.
Posted 09 September 2023 - 10:19 PM
The original Cooper S engines did and also the engine in the 1300GT I seem to recall was basically the same.
Posted 10 September 2023 - 09:18 AM
Posted 10 September 2023 - 01:30 PM
1300gt didn't have tappet covers. It had improved components over a 1275gt and a head shared with a mk3 Cooper S
My 1300 GT has tappet covers, and so does my 1275 Cooper S.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections โ
Problems, Questions and Technical โ
Brake Lights Stopped WorkingStarted by joobs1986 , 04 Dec 2024 ![]() |
![]() Installing Front Brake Shoe Retainer Springs (27H3753)Started by dschwartz1957 , 08 Nov 2024 ![]() |
Driveshaft Flange Looks WeirdStarted by Pietervdp , 02 Oct 2024 ![]() |
Is It Easy To Swap Post 84 Drums To Pre 84 Drums?Started by Daniel Watkin , 03 Aug 2024 ![]() |
Dunlop D1 Fitment And InstallationStarted by Mrhydro , 18 Jul 2024 ![]() |
