What make of 6 x 10 alloy rims have you got?
The tyres were almost impossible to fit to some of Midlands earlier 6x10 alloys because the recess was cast in the centre of the rim rather than offset to one side. The recess is there to make tyre installation and removal easier. When the bead ring of a tyre is fitted onto the wheel, it drops into the recess so the opposite tyre bead can be forced onto the rim without damage.
More details in TMF thread here:-
https://www.theminif...dish/?p=2005480
Quote:- "Are you thinking about getting them from midland wheel supplies? if so DONT DO IT! the ones from MWS are really dodgy, there is an inherrant design fault in them, i just got rid of a set. the problem is getting tyres onto them! it seems pretty much only MWS themselves can do it as they have some kind of magic/special tyre fitting machine that can do it? it is down to the position of the "well" in the middle of the wheel, and thats just the problem, its in the middle of the wheel, and not offset. i had 2 new yokos ruined when my tyre fitters tried to get them on, and i tried several other places too before looking it up on the net.
If you do a quick search on the net you will find plenty of people who have had the same trouble! i did see one guy, maybe off here, who brought a set off them directly, withtyres, and all was well until he tried to get 2 of the tyres replaced down the line, he had trouble with his usual guys, so went back to MWS and they fitted the 2 new ones, later the tyre bead gave out on the motorway and nearly totalled his car!
The tyre simply cannot stretch far enough to fit on the rim, and as such the bead end up ripping, and it seems if they do manage to get the tyre on after that, you end up with a lump in the tyre wall and eventually a blow out."
Edited by mab01uk, 14 September 2023 - 07:32 PM.
