Vtec Kit Driveshaft Specs
2 replies to this topic
#1 ImSteevin
ImSteevin
    Starting My Mini Up
  • 1 posts
Posted 27 August 2023 - 04:53 AM
I have a completed K20A car that has been sitting due to a failure of the right driveshaft on the highway years ago. Now that z-cars is closed, I assume I will need to get the part custom made.
The left driveshaft is still functional and installed. Can anyone confirm whether the two driveshafts were different lengths, or what the spline counts are for each end?
I've just begun looking into this process and I'd really like to get the car running again, so any information from someone who still has a surviving example would be a huge help. Thanks!
#2 Painter man
Painter man
  • 86 posts
Posted 22 September 2023 - 08:28 PM
Zcars is still running the new owner is called David rose he is a really nice guy but they are now based in Kent or you could try drd Racin they used to build stuff for the old Zcars in hull the owners name is Jamie or Carl at force Racin will make you one from you old one as a pattern
#3 Will_they_run_again
Will_they_run_again
    Just On Tickover
  • 6 posts
Posted 02 October 2023 - 03:21 PM
Is it not inner part honda outer mondeo, something like that anyways ?
