Steering Rack Tire Rod Nut Removal
4 replies to this topic
#1 foxroxracer
foxroxracer
  • 10 posts
Posted 20 August 2023 - 05:53 PM
Hello!
I'm in the process of restoring an 25th anniversary Mini (1984).
During the disassembly of the steering rack, I've stumbled upon a problem with removing the nut that holds the ball seat.
There are no sleeves cut into them, or holes for a C spanner.
I've tried to remove the nuts with a big pipe wrench but had no luck.
What is the best way to remove them?
Here are some pictures of the "nut":
Thanks!
KR
Sander
#2 stuart bowes
stuart bowes
  • 1,921 posts
Posted 20 August 2023 - 06:48 PM
Normally you would have the rack bolted to the car which holds one end tight, I guess you'll have to have it mounted in a vice or something instead
For the removal you can get an inner track rod end removal tool, it's basically a U clamp with a 1/2" square hole for ratchet / bar to connect to
Have a look on amazon or ebay shouldn't be any more than 12-15 quid or so
Edited by stuart bowes, 20 August 2023 - 06:50 PM.
#3 68+86auto
68+86auto
  • 713 posts
  • Local Club: Queensland Mini Car Club
Posted 21 August 2023 - 02:58 AM
That whole end is one piece which unthreads from the rack/"shaft". Buy a tool like this:
Attached File  Screenshot_20230821_125751_Opera.jpg   27.36K   4 downloads
Edited by 68+86auto, 21 August 2023 - 03:00 AM.
#4 Spider
  • 14,581 posts
Posted 21 August 2023 - 05:05 AM
I mount the racks in a Pipe Vice when doing them on the bench (actually, I never do them on car) and I have a C Spanner for them;-
If you don't have a Pipe Vice, you can make a suitable set of jaws from a piece of timber, put a hole saw the dia of the rack body through it, then cut it in half through the hole, use these in an ordinary vice.
#5 foxroxracer
foxroxracer
  • 10 posts
Posted 26 August 2023 - 07:09 PM
Thanks for the replies! I've tried making jaws with a wood piece but it keps spinning. I will have to buy the inner rack end tool, didn't know it existed! Thanks! KR Sander
