Metro Turbo Brake Conversion
#16
Posted 10 January 2007 - 10:27 PM
im going to bleed the system tomorrow and il let you know the results...
how did you get on with your setup jam2005?
#17
Posted 11 March 2007 - 08:15 AM
Have been advised all i need is the Metro - Mini Braided Hose, ERA Bolts and Metro Pads.
And thats it, probably the cheapest way to 4 Pot brakes by far!
#18
Posted 20 June 2007 - 07:21 AM
I recently bought a pair of 4pot calipers that I'm going to refurbish (by the way, hard job?).
I've read somewhere that 4 pots could fit under 10ers? is that right? I also read in another place that it could but involved drilling other mounting points. How hard/tricky could that be?
Thank you all for your help,
Marc
#19
Posted 24 June 2007 - 09:34 PM
#20
Posted 24 June 2007 - 09:53 PM
I like doing things myself but some things aren't worth it. You shouldnt need to drill new mounting points, although i did see some once but cant remember the reason they had to be done?
#21
Posted 26 June 2007 - 10:13 PM
2x 4pot calipers
2x brake discs
1x set of pads
2x metro drive flanges + 8 x bolts (disc to flange) may need to drill the holes to 10mm to fit the bolts through!(no big deal)
4x metro caliper bolts (ERA - although dont think available anymore)
1x braided hose conversion kit
1x pad retaining kit
fitting is mainly using a 14mm socket and also a 17mm socket, unsure of the hose spanner sizes atm!
basically whip the old kit off cut the caliper off the hose and unbolt from the subframe inside the inner wing 22mm i believe(dont count on it)
remove disc+ flange and tidy the area up maybe paint for extra life of the car!
then bolt the metro flange too the metro disc 42lB i think 17mm socket
slide the disc on hub.
install the hose kit and connect too the caliper use the join pipe to the second piston going top to bottom so not to trap any air in the loop!
mount the caliper too the hub with the era bolts(longer + stronger than std bolts for the extra force! unsure of torque
install pads + retaining kit.....then
BLEEDING THE CALIPER!
basically, bleed the lowest nipple furthest away from the car (this takes the longest 1-2 mins)
then the nipple on the other side at the bottom
then the top nipple (these take just a few seconds)
obviously you need to do the whole car not just these calipers!
then brace yourself for the first drive! LOL
#22
Posted 27 June 2007 - 10:29 AM
you can grind them off or machine them on a lathe
#23
Posted 27 June 2007 - 05:01 PM
#24
Posted 12 August 2007 - 07:13 PM
#25
Posted 12 August 2007 - 08:50 PM
mines servo'd and its a doddle to press the pedal!
#26
Posted 16 March 2008 - 12:42 PM
Some of the metro drive flanges have locating lugs on them you will need to remove these.
Do you have to grind the 4 ligs off each hub to fit particular wheels or is it required for all types of wheel (make, size and offset)?
[attachment=53270:Metro_Hub_Lugs.pdf]
#27
Posted 17 March 2008 - 04:43 PM
#28
Posted 19 March 2008 - 07:44 PM
#29
Posted 06 April 2008 - 08:32 PM
Or is using a grinder ok?
blakie
#30
Posted 04 May 2008 - 01:10 PM
