Clutch Throwout Bearing
Posted 06 August 2023 - 05:08 AM
Posted 06 August 2023 - 06:29 AM
We're the clutches correctly adjusted so that the bearing isn't in contact with the thrust plate when the clutch is released.
I've not had any failure with either the standard bearing from minispares or the heavy duty version other than both of them becoming a bit whirry/noisy when the clutch is depressed or the bearing is spun by hand.
I'm currently running a new old stock RHP version of the 'heavy duty' bearing. Still absolutely smooth and silent after a couple of thousand miles.
Posted 07 August 2023 - 03:15 AM
What bearings were they using?
Bearing is the same one usually found in the Borg and Beck clutch kit and correctly adjusted clutch lever. Would be nice if Timken made a throw out bearing.
Edited by croc7, 07 August 2023 - 04:56 AM.
Posted 07 August 2023 - 03:33 PM
