Rebuilt Engine Not Starting
engine electrical
42 replies to this topic
#31 Bobbins
Bobbins
  • 1,467 posts
Posted 15 August 2023 - 04:39 PM
First thing to check then, rotate the engine until valve no.8 at the opposite end is fully compressed, then check whether you have a massive gap in valve no.1, tip the rocker backwards if you can to check.
#32 Massee
Massee
  • 28 posts
Posted 15 August 2023 - 05:37 PM
There was no movement in rocker 1 at all,ive taken the head off, the pushrods are fine. I've put rods back in with head off and they all move as they should even both at no 1.
#33 Massee
Massee
  • 28 posts
Rocker 1 looked OK, so not sure if valves are stuck in 1
#34 viz139
viz139
  • 640 posts
  • Local Club: Irish Mini Owners Club
Posted 16 August 2023 - 08:27 AM
Check that the pushrods are all the same length and straight
#35 Massee
Massee
  • 28 posts
Posted 19 August 2023 - 09:53 AM
Pushrods are same length and straight.is it possible for valves to be stuck.dont know if there will be any damage to camshaft or followers, when I put All pushrods back with head off they all moved as they should
#36 KTS
KTS
  • 2,392 posts
Posted 19 August 2023 - 10:36 AM
assuming everything was setup correctly (especially valve clearances) i'd think it would be highly unusual for the valves to be stuck (closed) to such an extent that the mechanical forces of the camshaft lobes through the cam followers, pushrods and rockers would not be able to move them (without bending the pushrods)
if the pushrods are moving up and down as expected, but the valves themselves are not moving then the problem must be between the tops of the pushrods and the tops of the valves i.e the rocker assembly
have you gone through the process of setting the rocker-valve clearances ?
#37 Massee
Massee
  • 28 posts
Posted 19 August 2023 - 11:44 AM
I was going to check clearances but the no 1 valves weren't moving at all
#38 KTS
KTS
  • 2,392 posts
Posted 19 August 2023 - 11:49 AM
..quite possibly because the clearances haven't been set  ;D
#39 Massee
Massee
  • 28 posts
Posted 19 August 2023 - 11:54 AM
OK cheers, will have a go at setting it up
#40 gazza82
gazza82
  • 2,993 posts
  • Local Club: TMF+
Posted 19 August 2023 - 02:50 PM
When you turn the engine over are 1 & 2 pushrods moving?
#41 Massee
Massee
  • 28 posts
Posted 19 August 2023 - 11:31 PM
Not sure yet, but if they're not what would that mean? Thanks
#42 Bobbins
Bobbins
  • 1,467 posts
Posted 20 August 2023 - 05:38 AM
Rotate the engine until valve no.8 at the opposite end is fully compressed, then check what clearance you have between valve no.1 and its’ rocker. Tip the rocker backwards to check. Report back.
#43 Aly-g
Aly-g
  • 456 posts
  • Local Club: Still looking
Posted 16 September 2023 - 02:34 PM
Sounds like the cam followers are missing from no 1 cylinder ?take the cam cover off the back of the engine and check.
Allan
Edited by Aly-g, 16 September 2023 - 02:35 PM.
Also tagged with one or more of these keywords: engine, electrical
