Posted 03 August 2023 - 04:53 PM
Posted 03 August 2023 - 05:33 PM
Posted 03 August 2023 - 06:59 PM
Posted 03 August 2023 - 07:50 PM
The engine was rebuilt by good garage, I haven't checked tappets, is that worth checking?
As sonscar pointed out, above, until it starts everything is worth checking.
Posted 05 August 2023 - 02:37 PM
Try moving distributor round in increments?
Posted 07 August 2023 - 10:53 AM
ballat set up reduces voltage to coil when NOT cranking a drop to 9v under cranking is just battery voltage dropping. at 9volts is engine cranking over fast enough, check distributor by lining crank timing mark up with no1 on firing stroke and check rotor arm pointing to no lead may well be 180degrees out
Posted 07 August 2023 - 08:56 PM
Posted 09 August 2023 - 03:16 PM
Posted 09 August 2023 - 06:24 PM
Just to double check, firing order is 1, 3, 4, 2 and the rotor arm turns anti-clockwise.
Posted 09 August 2023 - 09:10 PM
Are the spark plugs wet with fuel after cranking?
Are you using enough choke (or too much)? What is the battery voltage during cranking?
What is the voltage during cranking on the coil positive? (what wire colours are on the coil?)
You need to check timing is set on correct stroke and that the valve clearances are set correctly...
Most important of all, how old is the fuel you are using?
What I'd do now is to pour a small amount (25 to 50ml will be plenty) of fresh fuel into the carburettor throat and see if it fires, runs and dies... If it does run it's a fuel issue, if not keep looking as its likely electrical or timing.
Coil wiring for a 12 volt car is White for coil positive
White/ black strip for negative.
Coil wiring for a ballast car is
Pink/white for coil positive (this is the ballast resistor)
Yellow/white wire to starter motor bypass feed)
white/black on cool negative
Edited by cal844, 09 August 2023 - 09:20 PM.
Posted 11 August 2023 - 04:43 PM
If you cannot get the distributor drive in at the correct angle ( between 1 an 2 o clock ) at TDC it is possible the cam is timed wrong. Do a compression test and if its low remove the timing cover to check the chain position.
Posted 13 August 2023 - 11:59 AM
Posted 13 August 2023 - 03:10 PM
#14
Posted 13 August 2023 - 03:12 PM
Posted 13 August 2023 - 07:00 PM
Also tagged with one or more of these keywords: engine, electrical
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 electrical |
Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
