8-Port On An Mpi Block
35 replies to this topic
#16 tmsmini
tmsmini
  • 723 posts
  • Local Club: MOASF
Posted 24 July 2023 - 03:29 PM
If I was more creative I could have come up with a better title. It seems MED can supply all of the parts to make the 8-port happen.
If I win the lottery, what way should I go to get a street-able exotic engine.
Vmax-SCART has the super chargers, SC has an assortment including the MPi turbo, KAD the sixteen valve, 8-port, 7-port?
How about a Ascaso Engineering block as a base?
I seem to remember an article on the Arden stated that ERA looked at the 8-port for their Mini, but decided on the turbo as the 8-port was a little too wild.
All would take some work to make a usable car, but with three Minis, it would be nice to have one that pushes close to the edge.
Interestingly enough Pierce used to be located about 50 miles from me, not sure here they are now.
https://www.piercema...com/Default.asp
Same general area, just a little further away.
Edited by tmsmini, 24 July 2023 - 03:32 PM.
#17 Quinlan minor
Quinlan minor
  • 1,153 posts
  • Local Club: LSMOC
Posted 24 July 2023 - 04:03 PM
If you win the lottery, Vetech's Hayabusa power plant is definitely worth looking at.
#18 imack
imack
  • 2,066 posts
Posted 24 July 2023 - 04:06 PM
If you win the lottery its got to be an Ascaso short motor with a KAD head.
#19 IronmanG
IronmanG
  • 1,223 posts
  • Local Club: Box hill. Lsmoc member
Posted 24 July 2023 - 05:46 PM
Trying to arrange a test drive in that
#20 brivinci
brivinci
  • 1,152 posts
Posted 03 August 2023 - 04:05 PM
Maybe the title should be: Open checkbook and the deepest of pockets build ideas:-)
First time seeing that aluminum block project! WOW!!!! Next level. Love that people are still developing these cars after all this time.
#21 Gaz66
Gaz66
  • 857 posts
Posted 03 August 2023 - 05:45 PM
I've just seen the accaso Dyno video on Facebook.
1071cc, 16v, turbo. 360bhp 220ft/lb torque at 8000rpm.
Unreal the development of this engine.
https://fb.watch/mbVGX08m0X/
Edited by Gaz66, 03 August 2023 - 10:44 PM.
#22 brivinci
brivinci
  • 1,152 posts
Posted 04 August 2023 - 06:01 PM
Its INSANE! Likely only matched by the price tag! ha
#23 imack
imack
  • 2,066 posts
Posted 04 August 2023 - 06:12 PM
Now upto 427bhp
https://fb.watch/mcZU6HSd4y/
#24 imack
imack
  • 2,066 posts
Now upto 427bhp
#25 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,026 posts
  • Name: Neil
Posted 08 August 2023 - 12:35 PM
A huge amount of work and it is impressive.
Expensive for most of us mere mortals BUT if you can afford it why not. I follow Steve Morris Engines on Youtube and his very own fully Billet big block (SMX) and LS (SML) V8's.
The amount of work involved is immense and the R&D that goes into this is off the scale. And of course so is the cost. https://www.stevemor...nes.com/engines
So i can fully appreciate what goes into these and also why they are expensive.
#26 DeadSquare
DeadSquare
  • 3,080 posts
Posted 08 August 2023 - 01:35 PM
Bl**dy facebook.
#27 PoolGuy
PoolGuy
  • 842 posts
Posted 08 August 2023 - 02:15 PM
Why not setup a FB account with a disposable email address and lock down all the settings so that you're all but invisible, you don't have to have any 'friends' and it enables you to view things from people who can't afford to advertise properly ;-)
#28 Steve220
Steve220
  • 5,016 posts
  • Local Club: BMC
Posted 09 August 2023 - 12:30 PM
I found his use of roller beings for the cam, genius!
#29 sonikk4
sonikk4
  • 16,026 posts
  • Name: Neil
Posted 09 August 2023 - 03:25 PM
Very much so but the thing I like about Steve is he is straight up honest about any mistakes he makes and then why the mistake happened and what he did to actually rectify the issue.
The eight con rods leaving the block is a perfect example and it also goes to show what repairs can be done to a Billet block over a cast one.
#30 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 19 March 2024 - 03:14 PM
Alternator location aside, the original 8 port was designed to be run with fuel injection.  I've seriously considered building an 8 port on MPI block, mostly as there are plenty of cheap unmolested MPI blocks out there.
The large valve 8 port heads recommend a +60 thou or 73.5mm piston. I understood that the modern Arrow/Saenz conrods will clear the cam lobes. Personally I'd run a pre-verto clutch as there are more options available and use a crank sensor on the crank damper; as opposed to the MPI that uses the flywheel for engine position.
While it's possible to set up a modern ECU without cam position it is a desirable thing to have. On non MPI blocks I've used a modified distributor for this. However, on an MPI block it's not so clear if the existing 8 port cams from MiniSpares/MED would work with the stock MPI cam sensor as I've no firsthand experience with the MPI blocks.
Edited by Curley, 19 March 2024 - 05:20 PM.
