Victor Reinz Headgasket
Posted 10 July 2023 - 02:48 PM
I've reached out to the directly, but no response yet.
Do I torque it like a copper gasket? or like a composite Payen type?
Any help greatly appreciated!
Posted 10 July 2023 - 04:08 PM
Keith Calver recommends applying Loctite 3020 to the Victor Reinz gasket. I don’t know why the torque would be different as it needs to suit the studs but please post if you find the answer.
Posted 10 July 2023 - 08:41 PM
Posted 11 July 2023 - 03:12 AM
I used the procedure in a 1980s Rover manual a few months ago and have had no issues since.
Posted 11 July 2023 - 07:07 AM
Posted 11 July 2023 - 09:05 AM
Both sides?
Posted 11 July 2023 - 10:07 AM
Both sides?
Yes, it comes in a spray can and he applies it to both sides.
Posted 26 November 2024 - 07:47 AM
For your interest
Edited by gaspen, 26 November 2024 - 07:47 AM.
Posted 26 November 2024 - 08:31 AM
For your interest
Thanks for that video. Just about to embark on my first head gasket change so really useful. It has got me worried though as I've just ordered the BK450 from Minispares to carry this out. It was recommended by their sales guy for my standard 1275. Should I be thinking of using the Loctite on this gasket. Bearing in mind I only semi-know what I'm doing, and don't want to have to repeat the job again if I can help it. Daz.
Posted 26 November 2024 - 08:50 AM
Every head gasket, except for solid copper and Cometic, I've ever had has heat release sealant already on them.
Posted 26 November 2024 - 09:03 AM
Do you mean it is not necessary the application of Loctite ?
I had to remove the head on my 998 and installed a Victor Reinz gasket but without Loctite.
It had a copper gasket before and I saw a little oil mist around the gasket. It is not a daily, rolled only ~1500km
Now with the VR gasket there is no oil mist - yet
Posted 26 November 2024 - 09:18 AM
When I installed a Copper hg on my 998 Clubby after having done some maintenance work there was oil seepage on several places of the hg.
Now I had checked the head for flatness and the block deck with no noticeable issues. Please bear in mind the head and block had not been touched other than cleaning.
The car drove fine with no noticeable decrease in oil level just this damned seepage.
After a quick msg to MS as they provided the hg kit they sent in what I believe was a Payen hg. Installed this and dry as a bone.
So the copper hg was torqued correctly and retorqued after one full heat cycle. I even checked it again before replacing it to see if anything had changed and everything was within specs.
So with this in mind and having seen multiple posts not only on TMF but on FB the consensus seems to be that both the head face and block need to be 100% true by re facing then the Copper hg should work fine?
Hopefully you will get your issue sorted. As for the OP, if Keith Calver says to use whatever I would say listen to the man as this sort of thing is his bread and butter.
Posted 26 November 2024 - 04:25 PM
For what ever it's worth, this is ACL's information and advice. Note in particular their advice regarding sealants and torque on page 3;-
Posted 26 November 2024 - 06:14 PM
I'm hoping it's the head/valve guides, as the smoke (which it has been doing for a while) is on first start from cold (worse if been sat for a week or more) and on gear changes/overrun.
Or it could be the copper head gasket? (Head gasket and valve seals replaced not that many miles ago) As I've only got excessive amounts of oil/fouled plug on the one cylinder.
But, I was intending on using the BGA composite head gasket, would I be best off using the loctite 3020 as well?
Also in the instructions it says to torque, loosen off 90degress/retorque. Run up to temp with coolant, allow to cool, loosen 90degress and retorque.
Or would I be better running without coolant? Fine on a fresh build, but as I don't plan on fully draining the radiator (I'll drain it from the water pump to below the head) Would leaving what coolant is left, and running without the alternator belt so the water pumps not turning be ok?
Edited by 1984mini25, 26 November 2024 - 06:15 PM.
Posted 27 November 2024 - 08:21 AM
"When replacing a cylinder head gasket additional sealing compound is required only when explicitly specified by the manufacturer."
https://www.victorre...e-Analysis.aspx
