Spot Lamps … Or Driving Lamps?
11 replies to this topic
#1 Bobbins
Bobbins
  • 1,486 posts
Posted 08 July 2023 - 02:01 PM
What’s the difference?
My ‘98 is running two spots and two o/e fogs but due to never using the fogs I’ve been considering a 4 spot lamp setup. I’ve seen some comments with other rally style setups (not Minis) where the inner two are spots, the outer two are “driving” lamps, what’s the difference though?
#2 Ethel
  • 25,919 posts
Posted 08 July 2023 - 03:57 PM
Width of the beam pattern, I'd guess. Always thought of the terms as interchangeable. I'd have thought 4 identical lamps with the beams in an overlapping fan would be the way, I'm clueless on the legalities for the road
#3 KTS
KTS
  • 2,421 posts
Posted 08 July 2023 - 04:45 PM
found this thread from 2013
https://www.theminif...-driving-lamps/
#4 Bobbins
Bobbins
  • 1,486 posts
Posted 08 July 2023 - 05:17 PM
Fantastic KTS, every days a school day as they say!
So spot lamps are long beam intense lights, driving lights are similar to the high beam of the headlights but probably more powerful as per the old Cibie Oscars.
#5 Avtovaz
Avtovaz
  • 1,232 posts
Posted 08 July 2023 - 09:49 PM
ive got the piaa that cooperman says about in that linked post, i run 1 spot and one driving on my road rally bmw, that way im sorted for a range of things. Lenses do look different but that dosnt matter to me.
they are fantastic.
#6 Cooperman
  • 23,276 posts
Posted 10 July 2023 - 12:54 PM
Before choosing auxiliary lights you need to decide what you wish to achieve.
Spot loghts give a long pencil beam so for main road fast driving they can be ideal.
Driving lights should give a more spread beam, but with more range than normal headlights, so for making good progres on twisty roads they are much better than spotlights.
#7 68+86auto
68+86auto
  • 899 posts
  • Local Club: Queensland Mini Car Club
Posted 11 July 2023 - 03:26 AM
A common thing is to run one pencil beam and one spread beam. Having only pencil beams on windy roads is not a good idea but you could fit some good headlights and use just the high beams in that situation. It all depends on when/where you actually think you will use them. The only situation that I believe I need additional lighting is when I drive hours in a straight line in remote areas so I am going to fit two pencil beams.
#8 weef
weef
  • 489 posts
Posted 11 July 2023 - 08:12 AM
Having all the bright auxiluary lights, of whichever design you prefer, are fantastic until you meet another vehicle on that twisty road and have to down to dip beam, your eyes take time to adjust and think "where did the road go".
#9 Ethel
  • 25,919 posts
Posted 11 July 2023 - 01:00 PM
Beats me why they make modern headlights that are brighter than daylight in the beam, abruptly turning in to pitch black out of them.
#10 unburntfuelinthemorning
  • 1,982 posts
Posted 11 July 2023 - 09:45 PM
This is a real issue.  All you can do is fit the best headlamps possible for the best dip beam pattern.  I find Cibie headlamps with high quality bulbs do a good job but an improvement on that would still be welcome for those times when it's wet out, you have to dip, the oncoming lights are very bright and the windscreen isn't quite as clean as you thought it was.
#11 coopertaz
coopertaz
  • 791 posts
  • Local Club: a-series-magpies
Posted 12 July 2023 - 10:21 AM
on other mini have 2 fogs and one spot on italian job bar have spot on seperate switch to full beam
#12 Ethel
  • 25,919 posts
Posted 12 July 2023 - 03:43 PM
All lights should dip on one switch to be road legal.
