They use to use 40mm itb with them that went down to 38mm which is still to big. Not sure what the port size is on the 8 ports. More like 32 or something?I think its such a shame about the current 7 port head as the idea is an excellent way round producing great power, I believe the heads are cast in the USA by a company called Pierce? why the company that flogs them over here doesn't ask for the ports to be cast smaller seems a bit wierd, with the right size ports you would think a +10FTLB per litre would be on the cards. An enterprising type of guy could take a bare casting to the Chinese tell the to copy it but with port revisions, then harden it properly and be on a right winner, especially if you got a common plenum designed and cast up at the same time, as this would bring the supercharged crowd into play as well.I think the 8 ports are ok as the ports are small. The 7 ports are to big so air speed is too slow so its not until 5000rpm that the torque is level with a 5 port.I was under the impression that 8 ports were supposed to produce better torque than the 5 port.
Pound for pound the 5 port has more torque until the higher rev range
Shooter
Edited by IronmanG, 08 July 2023 - 02:32 PM.
