Obviously would be sanding as much rust out as possible first
Would you then treat the area with Hydrate 80 or not bother?
Next a zinc primer question, is bilt hamber electrox zinc primer the same stuff as say Wurth Zinc Primer?
Would you zinc prime over hydrate 80 if you use hydrate 80 or is zinc primer mainly for clean metal?
So many primers and rust converters etc lol...
Also would you use an acid etch primer?
I already have Bilt Hamber Epoxy Mastic
