I did a complete engine and gearbox rebuild over the winter on my A+ engine with remote gearbox, KAD quickshifter and pre-verto clutch.
Both before and after the rebuild I am having issues with the reverse gear crunching when I try to select it, and often it feels like the gear shifter is in the correct place but the gear mechanism still isn't fully engaged. In some cases it will even jump out of the gear again. during my rebuild I did an inspection of the reverse gear itself but did not replace it as it seems to be in good condition.
I think I am dealing with two issues at once here. How do I stop the gear from crunching when the clutch is fully pressed and adjusted correctly, with all new hydraulic and mechanical parts?
And is there a way to adjust the gear selector somehow to make the gear "more engaged"? The gear shifter seems to go in to the location where it should be, but it is as if the movement is not enough to engage the gear, and often the gearbox will just stay in idle. And yes I do know that I have to pull the ring under the gearknob up to select reverse.
When I had the gearbox open I could easily engage and disengage the reverse gear manually using the shifter axel, so I would think the mechanics in the gearbox works.
