Fuel Pump And Starter Motor Issue
Posted 14 June 2023 - 08:28 AM
Posted 14 June 2023 - 10:05 AM
Check battery connections, especially the earth.
Posted 14 June 2023 - 10:29 AM
Battery and the connections are new. I replaced the earth cable to full metal one. Fuel pump issue is very rare and I am suspecting the relay box but as it is over £100 I just did not want to order.
Edited by hsular, 14 June 2023 - 10:29 AM.
Posted 14 June 2023 - 10:42 AM
The wiring may be new but are all the earth connections to clean, bare metal?
An intermittent connection will give the symptoms you describe.
Check, also, all the connections to the relay box.
At £100, it'd be worth getting the relay checked, by a competent auto-electrician, before replacing it.
Posted 14 June 2023 - 10:58 AM
I have opened the relay box 1 of the relays was a bit darker colour compare the others.
Posted 14 June 2023 - 11:55 AM
Are the relays all the same type? If so, or if there's at least one of the same type as the fuel pump relay, try swapping them over to see of the fault goes away. The starting problem sounds to me like a dodgy starter solenoid.
Posted 14 June 2023 - 12:58 PM
Try to connect between the starter main terminal and the wide spade terminal with some type of test lead (that will crank the engine over). That will eliminate the wiring and relay for the switching side, if a connection or component is in poor condition it often causes the issue you are having. I usually see this on vehicles without a relay to drive the solenoid but it could still be your issue if the relay or wiring is bad.
If doing what I just described doesn't work then the issue is in the solenoid, battery lead or earth cables (or the starter itself)
Edited by 68+86auto, 14 June 2023 - 01:00 PM.
Posted 14 June 2023 - 02:30 PM
I was talking about the relays inside the engine management relay box. They are soldered on so cannot change them I'm afraid. I am guessing the fuel pump is going as the car not getting any fuel while driving and loss of power. For the starter motor I will try to open it and see if there is anything unusual inside it.
Posted 14 June 2023 - 02:31 PM
I will definetely be trying this and report back.
Posted 15 June 2023 - 07:59 AM
Changed the fuel pump and ll good for now. I will give it 2 weeks to see if iot happens again. Starter motor issue still there. I will be looking into that and will let you guys know.
Posted 15 June 2023 - 11:02 PM
My bet is a defective ignition/starter switch. On my rally cars I have had ign switch issues and I fit a push-button starter switch with the Ign switch only activating the other circuits.
