Mot Advisories On Potential Purchase
suspension
5 replies to this topic
#1 billlifferr
billlifferr
    Starting My Mini Up
  • 1 posts
Posted 12 June 2023 - 01:07 PM
Hi all,
I'm looking to purchase a Rover Mini and am currently looking at a 1998 Cooper (Mk VII). The latest MOT had the following advisories:
Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (5.3.6 (a) (i))
  • Nearside Front Upper Suspension arm ball joint has slight play (5.3.4 (a) (i))
Should these be of concern?
#2 Cooperman
  • 23,225 posts
Posted 12 June 2023 - 10:41 PM
You need a Mini expert to look at the rear suspension mounting.
The ball joint is easy to rectify.
However, the main thing is to check for corrosion in all the other well-known Mini rust areas.
If you are unaware of where these are do not buy any Mini until you find an expert who will inspect it for you.
#3 nicklouse
  • 18,477 posts
Posted 12 June 2023 - 11:22 PM
Sounds like I fair MOT. Should be easily sorted. I would be more wary of one that said clean bill of health.
#4 floormanager
floormanager
  • 670 posts
  • Local Club: Mini Club Sussex
Posted 13 June 2023 - 06:54 AM
I'm in Sussex if you need advice / help
#5 mbolt998
mbolt998
  • 362 posts
Posted 13 June 2023 - 07:06 AM
Hi all,
If those were the only problems then you have a minter! The ball joints often have a bit of play and are cheap and fairly easy to replace. I would sort out the corrosion asap. It's not clear if they're talking about the body or the subframe.
#6 bpirie1000
bpirie1000
  • Area Managers
  • 2,316 posts
  • Local Club: Amoc
Posted 13 June 2023 - 10:21 AM
I would say join your local mini club and make friends quickly...
They are a font of knowledge and if you get the right person they can fix or point you to the mini friendly grages in your area....
Also tagged with one or more of these keywords: suspension
