Bought a second hand alloy rocker cover quite a few years ago - just tried to fit it but the T bolts aren't long enough ? can you get longer T bolts ? I notice that the rocker cover does not have recesses in the top where the bolts would go ?
any idea what rocker cover I have and what bolts I can use to fit it ? Its currently missing the spacer on each bolt and I had to cut down the rubber - rocker cover gasket not leaking at the mo but for how long ? ! IMG_5558a.jpg 76.09K 3 downloads
