Cannot Solve Pinging At Part Throttle With Vac Advance
16 replies to this topic
#16 CdnAustinAmerica
CdnAustinAmerica
  • 46 posts
Posted 07 June 2023 - 09:18 PM
That looks like about 2 deg btdc.
The fact that retarding the timing helps does make me question the part of carbon in the problem. That said taking the head off to clean it isn't the most complicated job. You can also measure the combustion chambers and the piston bowl to be certain the compression ratio is as low as you think it is.
Yeah I just don't have a lot of time to take the head off right now.
So am I right in setting it at "5" on the wheel with the light to get it actually to 7 btdc? Or do I have that backwards
#17 timmy850
timmy850
  • 3,327 posts
  • Local Club: MITG
Posted 07 June 2023 - 10:10 PM
With it running the strobe will fire when the plug fires. So if you want it set at 5, then the 5 needs to be where the timing pointer is. But the base timing is less relevant than the total timing and mid range timing
For reference the top dead centre mark is “1/4” which is when cylinders 1&4 are at the top
