Removable Steering Wheel
18 replies to this topic
#1 TAB348Y
TAB348Y
    Just On Tickover
  • 8 posts
Posted 03 June 2023 - 09:57 PM
With a lot of classic cars and minis being stolen id like to fit a removable steering wheel to My 1983 mini.
id also like to fit a 13” (350mm) deep dish suede steering wheel,
anyone fitted a removable?? Hard to find the right boss?? None of the mini shops seem to sell them.
any Advice and pictures would be great
#2 nicklouse
  • 19,067 posts
Posted 04 June 2023 - 08:33 AM
You have a few options. Get a boss that has the same patten as a removable adaptor. Or get a converter to change from your boss PCD to the adaptor PCD. Or you can get one of the steering columns with a weld on adaptor which will need the addition of a UJ between the colum and rack. This set up moves the wheel position less.
#3 imack
imack
  • 2,382 posts
Posted 04 June 2023 - 09:07 AM
A friend uses the "Go Race" steering column which is a modified column which is supplied with the weld on adapter fitted.
No free play in the quick release mechanism and the steering wheel remains in its standard position in relation to the indicator and wiper switches.
https://www.go-race....ck-release-boss
Edited by imack, 04 June 2023 - 09:07 AM.
#4 nicklouse
  • 19,067 posts
Posted 04 June 2023 - 12:32 PM
That’s the one I was thinking of.
And this what I was on about the adaptors. I wanted the wheel further back.
#5 DeadSquare
DeadSquare
  • 3,382 posts
Posted 04 June 2023 - 03:58 PM
You need to stop your car being towed away  --------------------  and broken for spares.
#6 TAB348Y
TAB348Y
    Just On Tickover
  • 8 posts
Posted 04 June 2023 - 09:00 PM
This looks brilliant!!! Maybe a little too much work for me, i was hoping for more of a bolt on and off job
#7 TAB348Y
TAB348Y
    Just On Tickover
  • 8 posts
Posted 04 June 2023 - 09:01 PM
I know, that’s the thing, even with no steering wheel it can still be dragged on to a trailer can’t it, might be one of a couple of things i can do
#8 TAB348Y
TAB348Y
    Just On Tickover
  • 8 posts
Posted 04 June 2023 - 09:02 PM
Just looked this up, this looks like a great piece of kit
#9 nicklouse
  • 19,067 posts
Posted 04 June 2023 - 09:09 PM
No such thing. The go race needs the extra UJ so you will be stripping down your steering column and modified it.
you could look at what removable kits are available that will fit the wheel you want and then see what bosses are available to fit the Mini. IIRC there are some but one (can’t remember the fitting) fell to bits when I tested it in the shop.
#10 imack
imack
  • 2,382 posts
Posted 04 June 2023 - 09:18 PM
The Go-Race column is a straight swap for the standard one, no UJ required.
#11 Gaz66
Gaz66
  • 1,202 posts
Posted 04 June 2023 - 09:20 PM
There are bolt on quick release kits on ebay for 20-30 quid which bolt on to your original boss.
A bit "ish" and chinese made so doesn't instill me with confidence when ripping round the lanes!
#12 nicklouse
  • 19,067 posts
Posted 04 June 2023 - 09:48 PM
Not seen the wheel end yet to understand how it fits through the column.
#13 imack
imack
  • 2,382 posts
Posted 05 June 2023 - 08:43 AM
The original steering wheel spline and thread is cut off the column and the quick release spline is welded on in it's place, therefore the column remains standard length and the Go Race quick release mechanism connects straight to the modified column and stalks remain within easy reach for road use.
#14 ac427
ac427
  • 739 posts
Posted 07 August 2023 - 08:04 PM
I noticed Mountney make their own quick release - https://www.opieoils...untney-qrh.aspx
BG make this one - https://www.merlinmo...y-bosses-bg4924
The Go Race one looks nice but it around double the price of the two above.
#15 nicklouse
  • 19,067 posts
Posted 07 August 2023 - 08:21 PM
One of those fell to pieces in the shop when I was looking at some.
