Check everything and assume nothing, but it does sound like a bent arm to me and given that it's the kerb side showing this, that is the more common one to get bent.
I have found them difficult to check off car unless you have a jig. Even on car, without suitable measuring gear, they are hard to check.
Take some measurements on the frame and check some angles, compare both sides. I had one of the first Minispares manufactured rear subframes during lockdown and had the same problem. Comparing both sides it was clear the end plate the arm pin locates through was welded a tiny bit out of line, which at the other end of the arm made a big difference. Minispares were great as usual and had another with me the next day.
This is a good point and one worth checking. All 4 holes for the Trailing Arm Pins should be in align when the subframe is true. I test for this in a similar way to how the factory did - I use a true rod, it's 1600 mm ling and 12 mm dia. (The factory used a 1/2" rod) It should be able to easily be easily fed through all holes at the same time without any need to bend it.
In lieu of using a rod, you can bolt on the outer arm brackets and look through from one side to the other, you'll see if there's any misaglignment here, however just be aware, depending on what brake valve you have, that maybe in the way here,
