Hello :)
I bought a beautiful 1981 Mini City, professing to be a no-issues smooth runner, with nothing but a hard-can-it-be attitude and experience on a cantankerous 1983 Land rover Defender. I'm a relative noob when it comes to engine building, having only had the previous 'training' of 'how do I fix this now broken thing'.... turns out the broken thing was my big end bearings.
A year and a lot of learning later, I'm now at the buying and rebuilding stage of this unplanned refurb and am looking for advice and tips on my current engine build plan. My local mini shop and this forum have gotten me so far, now for the final details :) the aim with this build is for a happily usable, often-as-she'll-let-me yet swift run around. I'm not after mega power, though after coming to the conclusion that I'm starting to get the bug, I've opted to err on the side of performance pieces where there was a nominal difference in part price, with the idea that I may well want to start upgrading her in the future. Why spend so much just to replace the same pieces later down the line.
Specs as I have them now:
12G949B head. Has 16F2 on a screwed-on plate(?) on the head, but can't find any info on this marking.
1275cc A+ engine. Machinist confirms she needs +20 thou bore
CAM6232 crank. 3rd journal was heavily worn (all 4 big end bearings were spun but this one was destroyed and splintered) so all big ends are being ground +30 thou, plus mains +20 thou
Cam has been identified as the OE 1275 A+ sprite/injection 50hp cam. It shows small wear on lobe 8 but machinist believes this to be fine for the application. Has been micropolished
Hif44 carb with cone filter
Old LCB standard exhaust was cracked at the point where the branches join, rather unsightly rust throughout too
Dizzy as yet unidentified, but given the state of the leads, rotor arm, coil and dizzy cap on disassembly I'm working on the idea that the dizzy is past her use by date
Also running a standard rod change gearbox, standard diff. Looked into X pin - think this may be overkill for the application but would consider it later down the line. On tear down, both box and diff seem in good condition.
What I'm now looking to rebuild to:
1293cc block with 10:1 compression ratio
Minispares evolution pistons
No change to crank or cam, just the grind /polish and fresh bearings to size
Keep the hif44, tear down and rebuild with a repair kit just to begin from a good base (on confirming the big end failure diagnosis, my local mini specialists got her running well as part of the issue was a broken carb spring making it impossible to tune the carb, making for funky running. They were happy with the carb at that stage but it's since been taken out during engine removal)
Maniflow Cooper freeflow exhaust system, single silencer with centre exit for a nice sound, good economy and no wasted power
Dizzy - C-27H7701 on mini spares
Also replacing of course the oil and water pumps, timing chain (sticking with single chain), clutch and coil as a minimum.
Already replaced in the effort to narrow down the problems at the beginning (to name a few) were the HT leads, rotor arm and dizzy cap. Old radiator swapped for a twin core. Head was cleaned up, skimmed 20 thou, with valve seats recut, guides checked and new valve stem oil seals put in (will replace now the head has been off again).
Once she's all back together I'd like to get her on a rolling road (handily we have a mini-specialist tuning shop with a rolling road within 30 mins from me) and get her tuned nicely to release the true power/performance from this set up.
My concerns/ areas for advice:
Machinist hasn't seen the conrods but having seen the crank, he thinks I need a new conrod #3. Do I need to/should I replace all 4 at once - I don't have funds to replace for new or forged, it will have to be a clean up and hone job on second hand ones.
Is a 10:1 CR correct for this application/set up?
How well recommended does the X pin diff really come?
ARP head and conrod bolts - are standard just as good for a road application? This is something I would change if looking to do a performance upgrade but does road require it really?
I was debating a stage one kit but I'm basically there with the work already done, though should I be looking at upgrading my carb needle when I rebuild it?
I'm currently getting a 23.6cc reading for head chamber capacity. To my research this is larger than original - could it have had work done already?
Should I be replacing the valve springs whilst I'm in there?
Is there anything else I should consider upgrading / doing some work to whilst I'm here?
Sorry for the long read - hopefully it will turn some gears in the heads of the great engine builders on here who can tell me if and where I'm going wrong before I steam ahead!
