Clutch Biting Point Is When The Clutch Pedal Gets All The Way To The Top
engine
2 replies to this topic
#1 TheRedBullet
TheRedBullet
  • 21 posts
Posted 31 May 2023 - 01:21 PM
i have a paddle clutch installed on my mini,the clutch biting point is when the pedal reaches the top(default position when not pressed). the car was only used 2 times with the paddle clutch, first time worked well and second time i got this problem. any help will help cheers.
#2 nicklouse
  • 18,400 posts
Posted 31 May 2023 - 01:28 PM
What flywheel set up.
sounds like poor set up.
#3 mbolt998
mbolt998
  • 354 posts
Posted 02 June 2023 - 10:08 AM
There is a little bolt you can adjust with a locknut that sets where the release lever returns to. Easy to reach and see under the bonnet. You might need to screw that into the flywheel housing a bit. You need two 7/16 spanners.
