I have been playing around with a 1.2L alloy block for some years, to hopefully sit it on a Mini gearbox.
The alloy casting has no provision for thrust bearings on the centre main, so I'm wondering if if would be sufficient to build the web up with Epoxy, to take a Mini thrust washer ?
I'm also wondering whether I actually need a thrust washer on the timing chain side, as it is only on over-run that the helical Diva gear pulls the crank towards the gearbox.
