Fitting 10” Wheels On My Mini Convertible (Spi)
suspension brakes
14 replies to this topic
#1 Dalla
Dalla
  • 14 posts
Posted 29 May 2023 - 12:43 PM
Hi There
I am considering fitting a set of 10” Force Racing ST10 Wheels on my Mini Convertible (SPI).
I see on the homepage that it states that these does not fit on Cooper S drive flanges.
As I am planning on fitting these on a Rover Mini SPI, I guess I will need to change to 7,5” brakes.
So my question is, do you know of a 7,5 brake kit that can use the SPI drive flanges, and do you know if the SPI drive flanges will work with the force racing wheels?
Could you please advise what I should do here?
Pic of car and wheels for attention
#2 DeadSquare
DeadSquare
  • 3,080 posts
Posted 29 May 2023 - 01:07 PM
You have a very nice, unusual Mini, which, because it is a convertible and not the classic Mini outline, doesn't look "wrong" because it hasn't got 10" wheels.
I'd keep it as it is.
It wouldn't be difficult to swap the hubs and fit 10" wheels, but there is a difference in the "Rolling Radius" of the tyres, which affects the Speedometer reading.
#3 mab01uk
mab01uk
  • 12,370 posts
Posted 29 May 2023 - 01:55 PM
I would also leave as is but if not:-
You will need a 10" wheel with a deep offset to fill the large Convertible arches. You will also probably need to lower the ride height with a Hi-Lo suspension kit.
7.5" Disc brakes will be needed to fit inside the smaller wheels, Cooper S Disc conversion kits from Minispares are the usual choice.....not sure why Cooper S drive flanges are a problem with your chosen wheels, perhaps ask Force racing what they recommend to be sure?
There is not much difference between the outside diameter of a low profile 13" tyre and a higher profile 10" tyre so the speedo reading should not be too far out but easy to check with a sat nav or by following someone with another car who will tell you what speed their car is reading against yours.
Lots of pics here to give you ideas of what can be done.
Tmf's Official 10" Wheel Thread Complete With Pics:-
https://www.theminif...lete-with-pics/
These genuine deep dish 6 x 10" Minilites from Minispares have a deep offset:-
Offset ET-15, SPECIAL 70mm backspace for Japan market originally.
This gives 4.25" outer wheel edge from hub face.
https://www.minispar...C-21A1902A.aspx
Edited by mab01uk, 29 May 2023 - 02:07 PM.
#4 nicklouse
  • 18,477 posts
Posted 29 May 2023 - 02:10 PM
Ok. You will need new calipers. Drive flanges.discs and maybe new brake pipes as they tend to fail when you remove them from the flex hoses which you will need to do to align the hoses correctly in the new calipers.
so quite a bit to do.
I would not as it looks great as is.
#5 Dalla
Dalla
  • 14 posts
Posted 29 May 2023 - 02:20 PM
Would prefer to run standard callipers, as danish authorities are quite strict.
#6 nicklouse
  • 18,477 posts
Posted 29 May 2023 - 02:25 PM
You can’t.  Like I said to run 10s you need the 7.5” disc set up. So drive flanges, Discs and calipers. Your 8.4” discs, drive flanges and calipers are not usable.
#7 Dalla
Dalla
  • 14 posts
Posted 29 May 2023 - 04:05 PM
So, i guess my question is, can you get some 7.5 discs where SPI drive flanges can be fitted?
Edited by Dalla, 29 May 2023 - 04:06 PM.
#8 nicklouse
  • 18,477 posts
Posted 29 May 2023 - 04:31 PM
No. They are totally different. And you will HAVE to change the calipers.
#9 Tupers
Tupers
  • 4,138 posts
Posted 29 May 2023 - 05:05 PM
You can get a 7.9” disc conversion from Mini Sport or KAD that will fit under most 10” split rims and use the latter 8.4” drive flanges but both require new 4 pot calipers.
Remember the clearance issue isn’t with the disc itself but with the caliper and how far out it sits on the hub to accommodate the 8.4” disc.
#10 Dalla
Dalla
  • 14 posts
Posted 30 May 2023 - 07:15 AM
Yeah Think i Will go with this. Probably the 7.75” kit from KAD.
#11 nicklouse
  • 18,477 posts
Posted 30 May 2023 - 07:23 AM
So you can change the calipers but not the drive flanges?
fitting the KAD. kit is more likely to raise questions as look quite different and don’t have any approval papers.
But retro fitting a complete kit from an earlier Mini is not permitted as the way the disc attaches is different meaning the drive flange is different!
I would be having a chat with my local tester to check out the options.
#12 Lplus
Lplus
  • 849 posts
Posted 30 May 2023 - 09:22 AM
As suggested above, talking to the testers would be helpful.  Are you required to stick with the setup as built?  in which case 8.4" discs and the standard calipers are mandatory. Or are you allowed to change to a different setup as long as it was fitted to a mini in its entirety at some point? in which case the 7.5" disc and cooper s calipers should be possible.
#13 Dalla
Dalla
  • 14 posts
Posted 02 June 2023 - 07:27 AM
No issue here is that i am not allowed to run 4 pot calipers, without some kind of approval (EXPENSIVE) Don't think they care/can see different drive flanges. Only thing was just that the Force racing wheels state that they do not fit with the Cooper S flanges
#14 KTS
KTS
  • 2,411 posts
Posted 02 June 2023 - 08:59 AM
Hi There
..speak to Force Racing and ask them what hub/flange/brake setup they suggest.  they should know
#15 Mr.greenPullover
Mr.greenPullover
  • 34 posts
Posted 04 June 2023 - 07:58 PM
First of all: It is Your Mini, do what ever You want and decide for Yourself if the technical and financial difficulties mentioned from the others are worth it!
But in my opinion You should also consider to You decision the look and if want to deal with the criticism of "Mini-Experts".
In my eyes 10 inch wheels under 12/13 inch arches (and vice versa 12/13 inch wheels under 10 inch arches) somehow don't look right. Technically the 10 inch wheels are only 4-6 % smaller and and the speedo would read a bit more but not enough to care really at the exact Mini speedos ;D
So my advice is to a) try to borrow that wheel or maybe a 4 spoke revo to put under Your arches to check if the look is what You imagined and or b) search the internet for a similar setup, like Your preferred wheels under sport pack arches.
Even the sport pack are still a bit wider - I think - the aesthetics work similar, so what looks good on sport packs, in my eyes also looks good on the cabriolet.
On my Cabriolet I removed the body kit, installed chrome bumpers, special arches and 10 inch revos. Especially in Germany at every Mini meet I got comments about "How could You have ruined such a special and rare Mini." Sadly more often than not, that are also the first comments I typically got. It's tiring...
On L2B last Year sadly I also got my first such comments in the UK.
To be clear, I don't moan about the people, who I had a nice conversation with and told me, that what I have done to my Mini don't fit their taste. That's perfectly fine, because if we all would have the same taste, we all would drive red Golfs...
I talk about the guys that only came over to tell me, I am an idiot that ruined my car...
Also tagged with one or more of these keywords: suspension, brakes
