Minisota Mini ('68 Mk2 1000)
54 replies to this topic
#46 jpsulisz
jpsulisz
  • 57 posts
Posted 14 January 2024 - 08:55 PM
Long time no talk, funny how life gets in the way!
My Mini got a new friend in the garage - don't worry, the mini is taking priority!
Attached File  IMG_4174.jpg   79.57K   0 downloads
With temperatures at -5 degree Fahrenheit I am thankful my heater was able to get it to 50 without much issue, here are the photos from yesterdays subframe removal. Every captive nut was seized and had to cut through the floor to get a 14mm on them to hold them still. As you can see from my photos that whole area needs to be cut out and rewelded in. I am a bit scared on how to handle the floor repair as well since I think I may be better off with an entire floor but not sure how I will support the car in that state.
I assume this is the original subframe, it is completely rotten on the drivers side, I knew this but didn't realize how weak it was.
Attached File  IMG_4285.jpg   99.09K   0 downloads
Attached File  IMG_4288.jpg   66.81K   1 downloads
Attached File  IMG_4290.jpg   72.7K   1 downloads
Attached File  IMG_4291.jpg   69.41K   2 downloads
Attached File  IMG_4292.jpg   100.72K   4 downloads
Attached File  IMG_4297.jpg   55.22K   1 downloads
#47 sonscar
sonscar
  • 3,257 posts
Posted 15 January 2024 - 09:39 AM
Looks like someone has been there before.Now just to cut it out and weld it back in.Enjoy,Steve..
#48 jpsulisz
jpsulisz
  • 57 posts
Posted 22 January 2024 - 03:35 AM
Underneath the left fender - looks like I will need tons of new metal around there and possibly a panel below the windshield.
Attached File  IMG_4317.jpg   58.02K   0 downloads
Removed the rear wiring harness this weekend and got supplies ready for stripping the rear of the car of rust. One issue I found is that there were sponges in the A-pillars that had a bit of rust. I imagine they soaked up moisture and have rusted the inner A pillars where the wires run. Not sure how I will go about handling that but writing this down so I remember it.
Anyway, with the rear lights and all the wires removed, this is what I am left with. I think before I build a rotisserie for it - I need to reweld in the wheel arches as they are in bad condition and don't like the 'repair' work done by the previous owner.
#49 jpsulisz
jpsulisz
  • 57 posts
Posted 24 January 2024 - 02:35 AM
Going through the rear of the car and finding a ton of bondo keeping the rear portion (below the tail gate) together. There are many patch panels (a few 2x3 inches) covering over rusted areas. I am also finding portions that I thought were solid, not! I think my main goal here for the weekend is to get the area around the wheel arches completely sanded/grinded down and point out structural issues.
I cut out the battery holder since it was in my way and was needing a replacement as well.
Edited by jpsulisz, 24 January 2024 - 02:36 AM.
#50 DoubleEh
DoubleEh
  • 22 posts
Posted 04 February 2024 - 12:27 PM
I feel your pain, my car was the same story! Everything that looked good was not and everything that looked bad was worse than it looked!
I'm getting to the re-installation process of the entire rear of my car so let me know if I can be of any assistance.
#51 jpsulisz
jpsulisz
  • 57 posts
Posted 30 March 2024 - 07:00 AM
Back at the Mini once again - I removed the engine and plan to have the rest of the interior and hopefully the front subframe out this weekend.
Attached File  1.png   574.5K   2 downloads
Attached File  2.png   582.87K   2 downloads
Attached File  3 (Medium).png   629.77K   1 downloads
Attached File  4 (Medium).png   616.03K   1 downloads
Attached File  5 (Medium).png   629.61K   1 downloads
The engine came out with not much issue - I did notice that the driveshaft seems to have damaged the transmission case at one point but overall in pretty good knick.
Attached File  IMG_4551.jpg   103.25K   1 downloads
Attached File  IMG_4553.jpg   104.82K   1 downloads
A long wait to work on the older Mini since I bought a newer 2018 Mini that needed some work, but is now my daily driver. :)
--Photo of when I was working on it
Attached File  IMG_4404.jpg   114.36K   0 downloads
We got some snow recently, my neighbors Nash is so sad :(
Attached File  IMG_4528.jpg   94.56K   0 downloads
Edited by jpsulisz, 30 March 2024 - 07:01 AM.
#52 jpsulisz
jpsulisz
  • 57 posts
Posted 08 April 2024 - 04:14 AM
Removed the front subframe out this weekend, wasn't very difficult but had no way to move it around the garage so i had to go to Harbor Freight and bought some dollys to move around. Have the car sitting on 2 30x8 inch boards but not liking how unstable it feels - will probably do a table for the bodyshell this week.
Besides the surface rust and what looks to be a grinder gash on one of the lower mounts I feel like I will be able to reuse this.
Attached File  Screenshot 2024-04-07 230939.jpg   75.8K   0 downloads
Attached File  IMG_4568.jpg   58.05K   0 downloads
#53 jpsulisz
jpsulisz
  • 57 posts
Posted 10 April 2024 - 01:37 AM
Originally I was going to get 2 pallets and throw some casters on there for a moveable base while I figure out the jig, but my local hardware store wanted $10 for a single one. I figured I could do better and built a base; I used spare wood I had lying around and topped it off with 6"x36" boards to disperse the weight. This is what I came out with, it rolls around my garage with ease but do wish I had some rope or something:
Attached File  IMG_4574.jpg   84.92K   0 downloads
Attached File  IMG_4576.jpg   89.45K   0 downloads
#54 jpsulisz
jpsulisz
  • 57 posts
Posted 15 April 2024 - 02:50 AM
Disassembled the steering, front lights, removed the passenger door, and had some trouble getting the gauges out as the last upper screw was stripped (my rotary tool broke so I have to pick one up tomorrow)
Attached File  IMG_4590.jpg   89.7K   0 downloads
The door was very sloppily connected, I removed the bracket and used an impact gun on the rear panel and the bracket crumbled as seen:
Attached File  IMG_4588.jpg   59.26K   1 downloads
Attached File  IMG_4589.jpg   43.39K   1 downloads
I have an opportunity to get a 1275 block, so debated that - but not really sure if itll be worth it; photos from the seller:
Attached File  435994910_968357698324568_2775238717033083922_n.jpg   45.34K   1 downloads
#55 jpsulisz
jpsulisz
  • 57 posts
Posted 07 July 2024 - 03:42 AM
Back to the grind -- removed the windows, now its finally down to a bare shell:
Attached File  IMG_4897.jpg   82.31K   0 downloads
Now - setting it outside while I clean the garage:
Attached File  IMG_4908.jpg   143.37K   0 downloads
I found a local supplier of a good aircraft paint stripper, works great -- tested it on a few panels and it has dramatically taken down the time to get to bare metal:
Attached File  IMG_4909.jpg   60.75K   0 downloads
Attached File  IMG_4965.jpg   77.22K   1 downloads
Looks like some bondo in that rear quarter!  >_<
The front left a pillar is a total loss:
Attached File  IMG_4911.jpg   50.77K   1 downloads
I decided to finally refurb that heater box -- currently awaiting them to dry over night:
Attached File  IMG_4910.jpg   65.52K   1 downloads
Yeehaw
Attached File  IMG_4964.jpg   58.97K   2 downloads
