Minisota Mini ('68 Mk2 1000)
54 replies to this topic
#31 Red Riley
Red Riley
  • 161 posts
  • Local Club: British Car Club of Charleston
Posted 11 September 2023 - 12:29 PM
When I saw the title of this thread, I was expecting to see this car.
#32 Colinmac1330
Colinmac1330
  • 257 posts
Posted 11 September 2023 - 04:12 PM
To be fair so was I!  :gimme:
#33 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 11 September 2023 - 04:26 PM
It’s not A+ . The generator is the giveaway as being an early engine. You’ll need to change a few things to suit a mini but it looks like a good base for a rebuild
If you remove all the spark plugs you should be able to turn it over by hand using the crank pulley. Pulling off the head is a good idea too
Yup, I put some MMO in the cylinder wells and letting it sit for 48 hours, adding more every 24 hours and monitoring levels. Will attempt to turn it over tomorrow morning probably.
I can barely squeeze in it as it is - going to have to chop off my head to get me in that!  :lol:
Edited by jpsulisz, 11 September 2023 - 04:27 PM.
#34 Sir_Swish!
Sir_Swish!
  • Just Joined
  • 20 posts
Posted 12 September 2023 - 08:54 PM
I love how honest and original this car looks, you're doing a great job of keeping it alive!  :D
#35 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 17 September 2023 - 04:32 AM
Tonight I went through the effort of replacing the entire clutch hydralics as I don't want to replace just the slave cylinder for the master to go out in a few months. I ran out of time to bleed it tonight and found out that the MiniSpares spring bracket that holds onto the transmission arm is too loose for my liking (Part #: 2A3601). I am sure it would work but I sanded down my old one and painted it black, letting it dry tonight. Going to try out my ezibleed I got for the clutch
After removal and slight cleaning of engine bay area - had a bit of fun removing the clevis pin in the engine bay since I thought removing the lever arm for the clutch would be too difficult:
Attached File  IMG_3937.jpg   59.67K   1 downloads
And post install:
Attached File  IMG_3942.jpg   56.99K   1 downloads
Here are the culprits to my failed hydralics; I think the boot may be well past due for a replacement, no? Will probably rebuild these over the winter.
Attached File  IMG_3939.jpg   38.81K   1 downloads
Attached File  IMG_3938.jpg   64.21K   1 downloads
Since I took out the seat to get the clevis pin for the clutch pedal I went through the effort of installing the seat bracket extenders as my seating area is a bit tight. However, I can't get past the first bolt of the standard seat bracket as I either hit the seat belt rolling base or the back of the seat hits the rear passenger side compartment. Moving it over closer to the center makes the rear legs hit the hump. Not sure why this is  >_< . Can't find any threads relating to this; I did remove the seat belt but it hits the rear passenger compartment and if I swapped seats I still get the same issue. Any advice on this?
Attached File  IMG_3941.jpg   45.84K   0 downloads
Attached File  IMG_3943.jpg   57.24K   0 downloads
#36 Jarvis_SPI
Jarvis_SPI
  • 53 posts
Posted 17 September 2023 - 02:15 PM
I thought that a '68 would have had static belts?
For later cars, the inertia reel was in the companion bin and the belt went up to the shoulder mount and back down to the sill mount where your reel is.
Where does the other end of your belt mount?
#37 timmy850
timmy850
  • 3,328 posts
  • Local Club: MITG
Posted 17 September 2023 - 09:20 PM
I had a similar experience with my Mk1. I added retractable seat belts and it gets very close to the mechanism. I ditched the extension brackets as they didn’t really get me any more length (and the cast finish of the Minispares items didn’t inspire confidence)
You could possibly try one of the extended brackets that keeps the seat frame on the same alignment as the factory bracket
https://www.retro-co...-brackets-pair/
https://jbfab.co.uk/...-seat-brackets/
#38 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 17 September 2023 - 10:06 PM
Mounts at the top of the B pillar seen here:
Attached File  IMG_20230917_163024_892.jpg   32.34K   0 downloads
Yeah, I ended up just moving it to the middle bolt as that clears the seat belt adjuster (just) and gives me a tad more room. Although my foot is still aching after driving it around so I need to figure out a better adjustment.
I bleed the clutch today with the ezibleed - somewhat disappointed as the schrader valve has a leak that I had to put a 2x4 against the tire to stop. It did work and was very easy, but not sure how I'll solve that issue.
I did have a considerable spill at the master clutch cylinder which I believe leaked into the interior a tad as I had a slight drip after bleeding. After an hour and cleaning, I don't have any drip anymore so I hope that the new cylinder isn't leaking, I'll look at it overnight.
Did an oil change, even used a NOS Saturn filter for the job!
I grabbed my thermal camera after driving a few miles around town to gauge if any of the bearing were shot - I think they look appropriate for drums, but let me know:
Attached File  IMG20230918055240.jpeg   256.07K   0 downloads
Attached File  IMG20230918055247.jpeg   310.63K   0 downloads
Attached File  IMG20230918055256.jpeg   271.4K   0 downloads
Attached File  IMG20230918055304.jpeg   241.27K   0 downloads
And while I am still running distilled water I grabbed some shots of the engine bay with the needle just past the middle mark of the temperature gauge - I think the readings here are fine too
Attached File  IMG20230918055313.jpeg   360.89K   0 downloads
Attached File  IMG20230918055334.jpeg   306.02K   0 downloads
EDIT: Hit save too soon
Edited by jpsulisz, 17 September 2023 - 10:16 PM.
#39 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 20 September 2023 - 07:29 AM
Have a slight weep of the new master cylinder and will need to redo all the brake lines as I had to refill the reservoir today. Will finally be ordering tires for it once my replacement card comes in. I have decided that first snowfall (usually mid october) or first brake/suspension failure will take the car off the road for a new rear subframe then front disc conversion (with all new brakes all around + new suspension (hydro to cone will be determined here)), and hopefully a bit of rust repair.
Here is a photo of todays drive to downtown Minneapolis, right along the Mississippi:
Attached File  IMG_3949.jpg   90.29K   1 downloads
My end goal here is for next year April-May to take the car 360 miles down to Chicago and September of next year to either make it down to Houston or go all the way to the West coast to drive through western portion of Montana, some of the roads there were just to die for when I went through in 2021. Look up Montana Highway 49 - it's usually empty at the end of the season.
This would mean making my mini into a makeshift camper - when I did the trip in 2021, I slept in the back of my Focus and managed to not go insane doing it.
Attached File  mt_2.jpg   43.22K   1 downloads
Edited by jpsulisz, 20 September 2023 - 07:44 AM.
#40 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 20 September 2023 - 01:57 PM
What a great road trip that will be! love the photo you posted,... where's the hood?
#41 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 21 September 2023 - 03:39 PM
Removed the hood when replacing the clutch hydralics - didn't put it back before the drive (can be a bit hard to line it up with just myself)
Last night did a coolant flush as I had been running distilled water in case of leaks. I spent so much time decided on coolant - I bought yellow/green HOAT coolant but read something where it wouldn't be ideal for older british cars as it can eat seals or something. I've read that blue is good, but not Asian blue, instead European blue but that green is a fine substitute. The car originally had green so I continued with old conventional green from o'reillys here. I will be returning the SuperTech stuff. All of this probably doesn't make that much of a difference and worried about it for nothing, I will replace it in a year or 2 anyhow.
Attached File  IMG_3955.jpg   43.61K   0 downloads
While I am sure some of this was oil from my pan, it still was this brown coming out during the first flush w/ coolant cleaner; after 3 flushes it came out clear:
Attached File  IMG_3956.jpg   54.61K   0 downloads
#42 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 22 September 2023 - 06:32 AM
So I've begun stripping the interior to get a better idea of what I am working with and oh boy I have begun searching for a new welder after I came in to clean up:
Here are my rear door pockets, the passenger sides frame rail isn't even connected toward the rear tire, not even sure if it's entirely safe to drive this thing anymore:
So I was already worried about the state of the rear subframe below the shock absorbers but now I am even more terrified with the condition of those rear passenger pockets as I understand is structural to the vehicle. If I am not mistaken, these are the inner sills and stiffener? But since the outer portion below the doors are slightly crunchy, that would indicate outer seals as well? Lastly a rear subframe mounting plate will also probably be in order. But if I do that, I can get ADO360020 which would allow me to replace the 'companion box' with a seat belt mount instead of the ashtray! Good excuse as the current placement is a huge pita.
Attached File  IMG_3967.jpg   69.89K   2 downloads
Attached File  IMG_3965.jpg   40.87K   1 downloads
Attached File  IMG_3964.jpg   36.99K   1 downloads
No pictures but I took apart the dash carpeting and I'd say its mostly okay besides a hair portion near the passenger door where I have a hole forming - but below that on the inner arch way there is a much larger hole that needs taking care of.
I found some cost saving installs by the previous owners:
Attached File  IMG_3960.jpg   27.5K   1 downloads
This was covering up the rust in the rear bin on the drivers side.
Attached File  IMG_3962.jpg   74.83K   1 downloads
but I did find this little guy hiding, so there's that!
Attached File  IMG_3961.jpg   30.44K   1 downloads
I have a gasless MIG 130 Flux welder, but I don't think it'll be suitable for this work. I am aiming towards the Eastwood 180 as it's what most of the people in the american MG forums recommend
#43 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 25 September 2023 - 02:53 AM
Begun tearing down the interior to see how the rest of the car faired. I could only get the interior out as I have a back injury and my movement is a tad limited. TL;DR: It needs more work, but overall, not bad for a car of this age. I believe the front subframe will need a removal to get remove to take care of this firewall rust.
I turned over the ADO16 spare engine I have - was able to turn it over by hand on the pulley so great news :
Attached File  IMG_3979.jpg   97.87K   0 downloads
Attached File  IMG_3980.jpg   91.13K   1 downloads
Rust pictures after carpet removal, very interesting to see how some of the rust repair is just silicone and black duct tape :|
Attached File  IMG_20230922_184107_560.jpg   61.75K   0 downloads
Attached File  IMG_20230922_184526_487.jpg   71.21K   0 downloads
Attached File  IMG_20230922_184543_448.jpg   31.62K   0 downloads
Attached File  IMG_20230922_192024_982.jpg   35.03K   0 downloads
Attached File  IMG_20230922_192016_409.jpg   53.94K   0 downloads
Attached File  IMG_20230922_190702_533.jpg   35.44K   0 downloads
Attached File  IMG_20230922_190644_286.jpg   47.69K   1 downloads
Attached File  IMG_20230922_184543_448.jpg   31.62K   1 downloads
Rear seat compartment with the original almond green:
Attached File  IMG_3978.jpg   49.74K   1 downloads
Very interesting seal here :?
Attached File  IMG_20230922_190638_789.jpg   42.91K   1 downloads
Edited by jpsulisz, 25 September 2023 - 02:54 AM.
#44 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 09 October 2023 - 03:28 AM
Not a terrible amount of progress has been done, mostly parts/tools hauling - I recently got a 2 rod change assemblies for the MG1100 engine, both seized. Yesterday I managed to free a single one and plan on soaking it in some degreaser this week and cleaning it up.
Attached File  IMG_4019.jpg   78.48K   1 downloads
Otherwise, I went to Wisconsin and picked up an engine hoist and picked up a PrimeWeld MIG180 (so this week and next week will be trying to do some 18-20 gauge testing). Doing a parts haul next week as well for the disc brake upgrades on my way to Chicago.
Getting the welder meant I had to wire in 220v in the garage and took the opportunity to add some additional outlets so I can have some lights above the mini!
Attached File  IMG_4025.jpg   85.21K   1 downloads
#45 jpsulisz
jpsulisz
  • Just Joined
  • 57 posts
Posted 06 November 2023 - 12:51 AM
Long time no see,
I was having some recent trips and was able to pickup some parts from Karl in Wisconsin (thanks again); I've got 2 older transmissions (if I dont use these I have a person in mind, these are mk1's from what I can tell) and most importantly got 4.5 rims on the chance my 3.5s dont fit!
Attached File  IMG_4091.jpg   49.19K   0 downloads
Attached File  IMG_4093.jpg   62.56K   0 downloads
Attached File  IMG_4092.jpg   56.21K   0 downloads
I began working on the rear subframe and began with removing some of the components and one of them is the hydrolastic suspension lines. I was able to depressurize the left side without much of a problem, I just halfway took out the valve but unfortunately the right side spring shot out and made the car look like it had an accident  O_O
Attached File  IMG_4130.jpg   107.21K   0 downloads
Otherwise, I was able to remove a majority of the rear components this weekend without much issue (and even got the right door off)
Attached File  IMG_4131.jpg   59.81K   0 downloads
Attached File  IMG_4132.jpg   116.82K   0 downloads
Getting ready to remove the rear subframe this week, I built a little platform to keep the rear of the car on. I think it's a bit overkill, I've seen people use a single piece of fibreboard to level the load across; but I also want to build tall wheel blocks to not rely on jack stands:
Attached File  IMG_4134.jpg   54.21K   0 downloads
Attached File  IMG_4135.jpg   48.89K   0 downloads
I will say that I have recently done some photography at the local SCCA rallycross and I am totally down to build this care to cater towards these small rallycross bits - seems really fun.
Recent photo from that event:
Attached File  DSC_4745.jpg   73.82K   0 downloads
