just fitted back the head, and installed a new Minispares C-27H001 distributor while at it.
Installed the dizzy exactly as instructed in the haynes manual (with the no. 1 cylinder at TDC).
Engine started up right away and seems to be running well, however with my timing light its showing the ignition advance at about 40 deg BTDC at about 1000 rpm which is weird. Plus when I rotate the dizzy anti clockwise, the rpms start dropping off right away and rapidly. So right now i have it turned as clockwise as it can go. Vac advance has been blanked off with a screw and some masking tape.
Have I perhaps gotten the HT leads mixed up? I'm thinking I should try shifting each of the leads one step clockwise?
PS: I have an additional mark on my cam pully at 20 deg BTDC so thats how I know how many degrees it is even though the A+ only has teeth to 24 degrees.
Edited by BaronVonchesto, 27 May 2023 - 10:13 AM.
