Idler Gear Bearings
Posted 22 May 2023 - 12:41 PM
I am in the process of changing idler gear needle rollers bearings.I ordered 2 *13H7848 bearings.
I measured idler shaft and both ends are approx 19mm.
Outside diameter of 13h7848 are approx 27mm. I offered up the bearing in the gearbox casing and it looks like it will fit. Yet when I look at the flywheel casing the hole measures 25mm and doesn’t look like it will fit.
Have I bought wrong bearings?.
Posted 22 May 2023 - 02:17 PM
There are 2 sizes of bearing used. And they are the same for the transfer case and the gearbox.
you have bought the correct ones for the early type boxes.
Posted 22 May 2023 - 06:24 PM
The early bearings, like those that would have been in your car are 1" OD. In 1968, they did increase these to 1-1/16".
While that does refer to the All Synchromesh Gearbox, there was a gradual introduction on the last of the 3 Synchro Boxes.
Be aware there bearings come in 2 types. Caged and Full Compliment. They are dimensionally the same as the Front Upper Suspension Arm, these are high load and low speed, so they use a full compliment type. The Gearbox is high speed and low(er) load and used a caged type.
Posted 23 May 2023 - 09:09 PM
Hi Spider, What is the physical difference between a full compliment bearing and a caged bearing?
Edited by ac427, 23 May 2023 - 09:10 PM.
Posted 23 May 2023 - 09:26 PM
There are spaces between the rollers in a caged bearing. As the cage holds them in place. Full comp has no cage but is filled with rollers so they are evenly spaced/supported.
Posted 24 May 2023 - 09:04 AM
The one on the left is a Caged Type
On the right, is a Full Compliment
