Are There Any Substitute Radiator Electric Fans From Another Car For The Spi Mini?
engine electrical
7 replies to this topic
#1 Asela Earthling
Asela Earthling
    Just On Tickover
  • 6 posts
  • Local Club: Mini Lovers Community
Posted 19 May 2023 - 08:18 AM
Hi, I'm from Sri Lanka and it is very expensive to source a new OEM replacement radiator electric fan from here. Is there any other matching substitute fan from another car that can be used on a SPI?
#2 greenwheels
greenwheels
  • 682 posts
  • Local Club: Mini Fixers
Posted 19 May 2023 - 08:56 AM
Try https://www.carbuild...?q=electric fan
#3 Ethel
  • 25,827 posts
Posted 19 May 2023 - 10:38 AM
I'm sure any pull fan of suitable diameter could work. The same one appears to be on the Rover 100, but I doubt that helps much.
Could replacing just the motor be an option?
#4 Asela Earthling
Asela Earthling
    Just On Tickover
  • 6 posts
Posted 19 May 2023 - 11:17 AM
Thanks for the link!
#5 Asela Earthling
Asela Earthling
    Just On Tickover
  • 6 posts
Posted 19 May 2023 - 01:23 PM
Hi, Thanks for the quick reply. I have to replace the fan because one of the blades is broken.
I was told the same by a local mechanic, that I can use a similar pull fan of the same size but that the rpm could be different. Since it's very warm here throughout the year, I want to find out if anyone has experience using a fan from another car with the same specifications to avoid fans with low rpm.
#6 Ethel
  • 25,827 posts
Posted 19 May 2023 - 01:30 PM
Speed won't mean that much as the blades will be designed accordingly. The power of the motor will be a better indication.
#7 cal844
cal844
  • 9,606 posts
  • Local Club: TFMOC
Posted 19 May 2023 - 07:05 PM
Ebay for a 12 inch universal fan.
Bypassing the temperature switch in the radiator for a manual switch on the dashboard.
#8 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 26 May 2023 - 04:05 PM
I use a 12 in universal fan. You should be able to get it at your local auto parts supplier. They should be pretty cheap. Just make sure you fit it so that it sucks air from the radiator side, and blow it out.
Most universal fans will be configured to blow air towards the flat side, so you will usually need to flip the fan round and connect it in reverse polarity.
Also tagged with one or more of these keywords: engine, electrical
