Sa Big Bore Engine Strip Down And Part Id.
27 replies to this topic
#1 nicklouse
  • 18,538 posts
Posted 09 May 2023 - 08:02 PM
Just picked this up sight unseen.
it has been opened up and had work done as the rods have been stamped. Turns over but has much rust.
#2 KTS
KTS
  • 2,420 posts
Posted 09 May 2023 - 08:24 PM
this should be interesting.  what's the plan ?
#3 nicklouse
  • 18,538 posts
Posted 09 May 2023 - 08:44 PM
 No plan. Just going to strip it so we can see what is inside as we so rarely see them in the UK. Or they are spoken about in hushed tones.
#4 imack
imack
  • 2,096 posts
Posted 10 May 2023 - 05:15 AM
Is it the one with the 1071 stroke crank?
#5 Spider
  • 14,797 posts
Posted 10 May 2023 - 09:04 AM
Seth Efrikan :proud:
#6 gazza82
gazza82
  • 3,005 posts
  • Local Club: TMF+
Posted 10 May 2023 - 09:33 AM
That's a A+ block isn't it? Same oil filter as the Marina/Ital inline engine ..
#7 Lplus
Lplus
  • 884 posts
Posted 10 May 2023 - 10:07 AM
No strengthening ribs and the mounting for the generator is in the old position for a dynamo.  The oil filter position is about the same as the marina and the Mpi minis.
#8 nicklouse
  • 18,538 posts
Posted 10 May 2023 - 12:02 PM
Nope. SA A.
#9 nicklouse
  • 18,538 posts
Posted 10 May 2023 - 12:05 PM
Strange lump on the crank.
#10 nicklouse
  • 18,538 posts
Posted 10 May 2023 - 06:57 PM
Oh look here
it seems it is a 1098.
#11 Lplus
Lplus
  • 884 posts
Posted 10 May 2023 - 07:37 PM
With an 11 stud 1300cc head.  That's a real bitza...
edit - that's a SA 1071cc S style crank.  Makes a bit more sense.
Edited by Lplus, 10 May 2023 - 07:39 PM.
#12 Gaz66
Gaz66
  • 876 posts
Posted 10 May 2023 - 08:12 PM
How come the SA stuff is so different to UK stuff.
I thought it would of made sense to standardise all bits no matter where they were going to be used.
#13 nicklouse
  • 18,538 posts
Posted 10 May 2023 - 08:24 PM
I thought it would have made sense to standardise all bits no matter where they were going to be used.
These were not made in the UK.  Their Minis were also quite different. Their MK3 had a hornet/elf back end. And there were others that had the elf/hornet front but the Mini rear.
#14 nicklouse
  • 18,538 posts
Posted 10 May 2023 - 08:26 PM
Yep basically a 1071s motor. Though I think the head was made 11  stud later on.
loads of rust but it dose turn easily.
#15 timmy850
timmy850
  • 3,305 posts
  • Local Club: MITG
Posted 10 May 2023 - 11:45 PM
The reason for the SA 1100 engine was that they could use the same block & head and make 2 different engines - 1100 and 1275. They only needed to swap the crank and pistons (similar concept to the 998&1098 engines)
The SA 1100 engine had heavy pistons with a much bigger wrist pin height, and weren’t considered to be performance engines.
Attached File  IMG_2232.jpeg   75.43K   1 downloads
I have an SA1100 crank for my next engine build and it’s a 70.0mm stroke, which makes it a 1096cc engine. The bearing sizes are the larger 1.75” (unlike the S engines that used 1.625”). The lump on the crank web is a standard feature
Attached File  IMG_2243.jpeg   55.23K   1 downloads
Edited by timmy850, 11 May 2023 - 12:52 AM.
