Strong Fuel Smell In Garage.
10 replies to this topic
#1 Cooper Mac
Cooper Mac
  • 222 posts
Posted 09 May 2023 - 02:07 PM
Hi all!
I've recently got the mini engine fired into life, but now when I go into the garage, there is a very strong smell of petrol!
There isn't any smell of petrol inside the car, but the garage stinks!
During the car's rebuild, I have cleaned out the fuel tank, this is leak free, so no fuel in the boot, and therefore no smell inside the car.
I have replaced the copper fuel pipe under the car, and it has a new mechanical fuel pump.
The tank has a new breather pipe.
All of the flexible fuel hose has been replaced with CODAN J30 R9.
I did spill some fuel when I was trying to prime the pump last week, but this was outside the garage, and I'm sure that I wiped up any spillage.
I can't find any sign of a leak, so I'm not sure what it could be?
Could it be the changes in weather and the fumes coming out of the tank breather? I have approx 20 litres in a 34 litre (7.5 gallon) tank.
#2 SKIDDERWOLF
SKIDDERWOLF
  • 296 posts
Posted 09 May 2023 - 02:14 PM
Probrally from the tank breather pipe which exits beneath the rear subframe mine stinks too.
#3 Chris1275gt
Chris1275gt
  • 938 posts
Posted 09 May 2023 - 03:39 PM
My garage used to smell of petrol finally found a decent non vented filler cap but still used to get a whiff with the weather change so got a bit of sponge ( not closed cell type) pushed a bit up the small vent pipe underneath the car and not smelt in since, and never had a problem with it.
#4 sonscar
sonscar
  • 2,997 posts
Posted 09 May 2023 - 07:28 PM
I like the smell of the garage in the evening after a hot day,petrol,rubber,oil,old car smells.Take a good coffee sit down and contemplate life.Nice,
Check that the fuel is not overspilling into the carb due to leaky float valves,Steve..
#5 Cooper Mac
Cooper Mac
  • 222 posts
Posted 11 May 2023 - 10:51 PM
I think this is where it is coming from but the smell is quite strong!
Is there any kind of filter ai could put on the end of the breather to reduce the fumes?
#6 SKIDDERWOLF
SKIDDERWOLF
  • 296 posts
Posted 12 May 2023 - 03:46 AM
I don't know although have often wondered the same too. Somthing carbonbased might work - Hopefully someone more experienced could provide some advice. Or I may try what has been suggested about shoving some foam up the hole.
#7 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 12 May 2023 - 05:57 AM
The factory solution was a charcoal canister and allowing the fumes to be drawn into the intake under certain driving conditions
Eg
https://www.somerfor...ve-loss-control
#8 Steam
Steam
  • 757 posts
  • Local Club: Victorian Mini Club
Posted 12 May 2023 - 07:03 AM
Make sure the fuel tank filler cap has a good sealing gasket. That is a more likely place than the breather for a strong smell.
#9 Cooper Mac
Cooper Mac
  • 222 posts
Posted 17 May 2023 - 12:42 PM
Update:
So, I’ve added a loop of fuel hose, and a plastic fuel filter onto the end of the breather pipe and cable tied it onto the rear subframe, as below:
This seems to have cut the smell of fuel considerably! I also noticed that I have a vented fuel cap, so I have ordered a non-vented cap, to see if this reduces it further.
I’ll update when I have fitted in trialed the non-vented fuel cap!
#10 nicklouse
  • 18,583 posts
Posted 17 May 2023 - 01:35 PM
Check the carb overflow.
#11 Cooper Mac
Cooper Mac
  • 222 posts
Posted 17 May 2023 - 02:11 PM
Hi Nick, I’ve checked and the carb overflow continues to be dry.
Thanks!
