Bonnet And Grill Gap Adjustment Problem.
#16
Posted 01 May 2023 - 07:19 AM
#17
Posted 01 May 2023 - 08:10 AM
Screenshot_20230423-183810_Facebook.jpg 31.12K 1 downloads Screenshot_20230423-183058_Facebook.jpg 23.02K 1 downloads^ this is why I'm planning for a gas strut on each side, having had a few cars with that as standard I really can't be doing with the old school piece of metal rod flapping about
#18
Posted 01 May 2023 - 08:41 AM
yeah that looks good, the wider opening is obviously a massive improvement over the original as well what with me being a full sized human not 3 foot 7 lol
#19
Posted 01 May 2023 - 08:51 AM
#20
Posted 29 February 2024 - 05:22 AM
You may find the hinges and catch are fighting each other so it twists the bonnet as it clicks closed. The best way to sort it is to remove the pin and spring. Adjust the hinges so it shuts square with the best gaps around the edges and height at the back. A little pressure on the front to simulate the catch holding it down onto the stops may be necessary. Once you've got it sitting right, refit the catch pin etc. Close the bonnet slowly and watch how the pin engages with the catch. You will probably need to loosen the bolts and adjust the alignment of the pin and catch so it doesn't skew the front of the bonnet as it clicks shut. If there are no stops, fitting some stops will help.
