Bonnet And Grill Gap Adjustment Problem.
19 replies to this topic
#1 KobukKobuk
KobukKobuk
  • 70 posts
  • Local Club: Mighty mini
Posted 25 April 2023 - 11:36 AM
Hello. Good morning.
This is a question for troubleshooting.
The gap between the bonnet and the grill is different. (see arrow)
What I tried was adjusting the bonnet hinges and twisting the bonnet, but it didn't work.
(It seems that one side is twisted the moment the bonnet is closed.)
What could be the problem? Any advice please!
Edited by KobukKobuk, 27 April 2023 - 08:32 AM.
#2 stuart bowes
stuart bowes
  • 1,942 posts
Posted 25 April 2023 - 11:50 AM
which side lines up best with the wings
also a picture of that slam panel with the bonnet open may help
#3 KTS
KTS
  • 2,390 posts
Posted 25 April 2023 - 05:59 PM
do you have bonnet buffers fitted to the slam panel ?
if so, adjust (shorten) the bonnet lock pin so that the bonnet (just) rests on both buffers when shut
that in theory should mean the bonnet sits level and doesn't rattle
#4 stuart bowes
stuart bowes
  • 1,942 posts
Posted 25 April 2023 - 06:54 PM
^ that's what I wanted to see yeah
If anything it looks like drivers side is too high so possibly the passenger side one is missing
My old escort years ago had sort of screw in and out rubber bump stops, they made adjustment very easy
Edited by stuart bowes, 25 April 2023 - 08:44 PM.
#5 IronmanG
IronmanG
  • 1,212 posts
  • Local Club: Box hill. Lsmoc member
Posted 25 April 2023 - 10:38 PM
Yep third that. Think this was brought up a while ago and bonnet buffers were missing?
#6 KobukKobuk
KobukKobuk
  • 70 posts
Posted 26 April 2023 - 12:22 AM
On the left side (driver's seat), the grill side has a gap, but the top of the bonnet and the wing gap are narrow.
On the right side (passenger seat), the grille side is narrow and the gap between the bonnet and wing is relatively large. Could this be a hinge problem?
#7 KobukKobuk
KobukKobuk
  • 70 posts
Posted 26 April 2023 - 12:26 AM
There was no bonnet buffer (thanks to that, I learned the name), and I thought the Classic Mini didn't have it.
Perhaps the hole in the arrow in the picture is the seat of the bonnet buffer?
I'm going to use another vehicle's bonnet buffer and put it in there to adjust it.
Thanks~
#8 sonscar
sonscar
  • 2,921 posts
Posted 26 April 2023 - 07:17 AM
Mini bonnets and hinges are very flimsy and respond well to subtle force to align them.They are so flimsy they move about on their own.Steve..
#9 stuart bowes
stuart bowes
  • 1,942 posts
Posted 26 April 2023 - 08:12 AM
these are the points I was referring to originally:
post-130883-0-41113900-1682468536.jpg[/url]
I'd be trying to make those look the same by either twisting it by hand (gently bit at a time) or by adding rubber bumper(s) as above
then see where that gets you with the chrome strip and let us know
I would be fine with the back end near the hinges, others might be more picky
Edited by stuart bowes, 26 April 2023 - 08:14 AM.
#10 KobukKobuk
KobukKobuk
  • 70 posts
Posted 26 April 2023 - 09:05 AM
yep. I will try as you said.
Thanks for your kind advice.
#11 GraemeC
GraemeC
  • 7,418 posts
Posted 26 April 2023 - 01:00 PM
Only the clubman had adjustable bonnet buffers from the factory. You may be able to get a buffer from another car to work, but it will need to only be very small in height.
The standard buffers were only a few mm high.
http://www.minispare...56.aspx|Back to
#12 cooperd70
cooperd70
  • 703 posts
Posted 26 April 2023 - 01:10 PM
My bonnet looks just like yours with the driver side higher at the front at slam panel than the passenger side....going to try the 'gentle twisting by hand method as well' 👍👍
#13 stuart bowes
stuart bowes
  • 1,942 posts
Posted 26 April 2023 - 01:19 PM
emphasis on gentle...   if for no other reason than they are expensive new and hard to find decent quality used without being full of rust
and I don't want anyone coming back and cursing me for suggesting it lol (but I wasn't the only one)
Edited by stuart bowes, 26 April 2023 - 01:20 PM.
#14 sonscar
sonscar
  • 2,921 posts
Posted 26 April 2023 - 04:19 PM
Every time you use the bonnet prop then you twist the bonnet.You may be twisting it often by default.Steve..
#15 stuart bowes
stuart bowes
  • 1,942 posts
Posted 30 April 2023 - 05:05 PM
^ this is why I'm planning for a gas strut on each side, having had a few cars with that as standard I really can't be doing with the old school piece of metal rod flapping about
