Mk1 Door Cards
7 replies to this topic
#1 theoldmini
theoldmini
  • 130 posts
Posted 09 April 2023 - 07:08 AM
My new door cards have arrived from Newton commercial.  At what point do I fit the drain pipes.  Before or after fitting cards as I see at the bottom the card sits between panel and drain but not sure about the top.  First time I have done this so need guidance.  Thank you
#2 KTS
KTS
  • 2,390 posts
Posted 09 April 2023 - 12:19 PM
fit the drain pipes (and the door locks) before the door cards
the tops of the door cards are held in place by the two fillet pieces at each side
i found it easiest to bias the door card toward the rear of the door when inserting, and slide them forward when they're in.  also worth propping the door from below with a couple of blocks of wood to stop it shifting on the hinges whilst wrestling the door cards/drain pipes etc into place
#3 theoldmini
theoldmini
  • 130 posts
Posted 09 April 2023 - 05:06 PM
Thank you.  I have a long handle on the inside near to the door lock.  With this in situ it gets in the way of door card. Do i fit the lock and outside handle then fit door card and then undo handle to slide long handle onto the shaft.  More guidance needed thank you.
#4 Alex_B
Alex_B
  • 4,573 posts
Posted 09 April 2023 - 05:12 PM
I personally removed the door latch and handle (also running the long handle), fitted the door cards and then refitted latch assembly. It needs all three pieces to be loose and assembled together then screw outer handle on, then inner latch.
If you follow Newton Commercials instructions it gives you a good idea on how to fit the cards too, its not hugely difficult but a bit fiddly.
#5 KTS
KTS
  • 2,390 posts
Posted 09 April 2023 - 07:44 PM
Apologies, I meant fit the escutcheons to the doors first. As above, take the handles out to get the internal levers out of the way and then refit after. Passenger door handle should pull straight out, drivers side needs a quarter turn of the key to release it
#6 theoldmini
theoldmini
  • 130 posts
Posted 14 April 2023 - 01:42 PM
All fitted and look good.  Thank you for input .  Whilst here where can I get the vinyl trim that goes round the rear windows and rear doors on an estate.  Have tried Newton but on;ly sell in a kit.   Appreciate guidance   thank you
#7 KTS
KTS
  • 2,390 posts
Posted 14 April 2023 - 02:40 PM
might be worth  a call to Optimise to ask
https://www.optimise-automotive.com/
or message roberts on the forum
https://www.theminif...mini-interiors/
#8 theoldmini
theoldmini
  • 130 posts
Posted 23 April 2023 - 08:43 AM
Have tried Optimise but in the e mail they say will need originals problem is I don't have any.  Any other ideas please
