Is There Any Original Speakers?
Posted 08 April 2023 - 04:03 PM
Anything is helpful
Posted 08 April 2023 - 04:07 PM
Usually pods mounted on rear parcel shelf or fitted under rear seat.
Posted 08 April 2023 - 07:13 PM
Originally there was a single mono radio speaker fitted by your Dealer centrally under the rear parcel shelf from inside the boot. Under the trim there are two large holes in the centre of the metal bulkhead shelf for an oval speaker attached by 4 screws/nuts. A grille would then be fitted over a suitable hole cut in the trim.
Later Minis had two extra speaker cut-out holes at each end of the rear parcel shelf for fitting aftermarket stereo speakers!
Edited by mab01uk, 08 April 2023 - 07:14 PM.
