Spraying A Plastic Bumper
5 replies to this topic
#1 wilsonch
wilsonch
  • 120 posts
Posted 03 April 2023 - 01:12 PM
Sorry if this isn't classic mini related but it is a BMW mini question, but a general question.
My son has an R56 cooper s rear bumper that needs spraying, its second hand (but the same colour as his car) it has had some repairs done, the parking sensors have been removed and filled.
The 'repairs' are too big just to patch up so I need to sand off the whole thing (not to bare plastic just to give a good key) and re-undercoat and spray.
I have watched quite a few YT vids but just wondered if there are any members who have experience in plastic panel spraying.
And pointers welcome.
#2 nicklouse
  • 18,577 posts
Posted 03 April 2023 - 01:58 PM
Get the correct primer. Otherwise I just treated it the same.
#3 Homersimpson
Homersimpson
  • 829 posts
Posted 03 April 2023 - 02:14 PM
If you are just painting over existing paint then treat as normal but as above if any of it is bare plastic then you need to use a proper plastic primer before normal primer and paint.
Have the repairs been done using the correct plastic filler/repair materials and has any primer been applied over the plastics primer?  If someone has just repaired it then it may not work/last.
#4 wilsonch
wilsonch
  • 120 posts
Posted 04 April 2023 - 04:37 PM
So they have filled the holes with plastic circles and used those plastic welding wighly things and filled with regular filler..... That i have now removed and used flexible plastic filler.
There are some bare plastic and filler parts that will need plastic primer.
When you say 'treat as normal' do you just mean sand and colour coat, no primer?
#5 Homersimpson
Homersimpson
  • 829 posts
Posted 04 April 2023 - 07:14 PM
If your are painting over sound paint then you don't need to use primer, as this isn't the case you will need to use a plastic primer and then normal or epoxy primer and then paint (obviously sanding the primer before painting).
#6 wilsonch
wilsonch
  • 120 posts
Posted 05 April 2023 - 04:26 PM
Many thanks for the advice.
