Cracked Fly Wheel Housing First Motion Shaft
Posted 01 April 2023 - 05:01 PM
Loud bang when tightening bolts.
I put a bit (more than a lick) of grease on shaft to aid assembly.
All seemed good until I pulled the housing up with nuts.
Is the oil pressure enough to force a leak?
Can it be welded ?
Posted 01 April 2023 - 05:05 PM
Edited by Verderad, 01 April 2023 - 05:09 PM.
Posted 01 April 2023 - 05:11 PM
Just a simple job!!!
Feels expensive and a delay.
Had it vapour blasted £40 down the drain.
Anyone want a part finished project?
Posted 01 April 2023 - 05:18 PM
Why did I want to have a nice looking engine?
Posted 01 April 2023 - 05:27 PM
Oh dear,,,,,,
It's always a good idea to rotate these shafts as the cover goes on, that aids the rollers of the outrigger bearing seat and not catch on the out race.
It could be repaired, it will need welding and machining but a replacement would be much cheaper.
Posted 01 April 2023 - 05:32 PM
Did the idler gear shaft fit into the bearing ok?
I've had modern Chinese pre a+ idler bearings which appeared tapered.
The shaft would go in about 1/2 way and then bind.
Posted 01 April 2023 - 05:41 PM
That's the idler gear bearing housing not the input shaft bearing.
Posted 01 April 2023 - 08:00 PM
I noticed that a guy had three housings on ebay, about 10 days ago, but I didn't study price or location.
