Posted 01 April 2023 - 04:01 PM
Posted 01 April 2023 - 06:03 PM
Posted 01 April 2023 - 07:26 PM
Posted 02 April 2023 - 02:27 PM
Changed the rocker cover on my 1993 mini sprite today, no oil leaks etc when I started it up after. Left it off for an hour or two, then started it again. Drove it for a short while and realised that I was losing a lot of coolant, so shut it off immediately. I'm not sure where to start now, looks like it is dripping from the bottom of the radiator. Any help would be much appreciated. Thanks, wyatt
Bottom of the radiator would be a good place to start checking.
Edited by bpirie1000, 02 April 2023 - 02:28 PM.
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
