Grille Attachment System
16 replies to this topic
#1 mbolt998
mbolt998
  • 369 posts
Posted 24 March 2023 - 05:26 PM
Everyone knows how annoying the self-tapping screws that hold the grille on a Mini are. You need to keep taking the grille off to reach anything, especially the distributor. Every time you do the screws get a bit looser, and before long most of them fall out on the road somewhere. Captive nuts seem to be what are needed but if the front panel is on the car it's pretty hard to get behind/inside it.There are various official solutions but I'm quite pleased with the below and think it might actually work.
Step 1, clean up the existing hole (the pencil is because there seem to be some wires running inside there that I was keen not to drill through)
Attached File  1.jpg   38.13K   3 downloads
Step 2, drill it out to 8mm
Attached File  2.jpg   36.33K   2 downloads
Step 4, make this in mini-lathe. OD is 8mm, ID is 4.2mm. Then I cut off a piece about 3mm thick.
Attached File  3.jpg   37.65K   1 downloads
Step 5, insert into hole:
Attached File  4.jpg   38.91K   1 downloads
Step 6, weld it on carefully
Attached File  5.jpg   46.96K   1 downloads
Step 7, grind it down somewhat flat
Attached File  6.jpg   40.36K   1 downloads
Step 8, tap it to M5
Attached File  7.jpg   41.81K   0 downloads
Works like a charm. Not going to use Allen bolts like this but something with flatter heads. But the point is it's got 3mm of metal behind there to screw into with a proper thread in it, similar to a nut, only welded on from the front.
Attached File  8.jpg   26.14K   2 downloads
#2 DeadSquare
DeadSquare
  • 3,088 posts
Posted 24 March 2023 - 05:40 PM
That is a much more Pukka job than my 'bungee' hooked round the plastic dipstick guide.
#3 Shooter63
Shooter63
  • 1,018 posts
Posted 24 March 2023 - 06:23 PM
If you don't mind me saying, why didn't you just use some rivnuts?
Shooter
#4 I hate Brian
I hate Brian
  • 782 posts
Posted 24 March 2023 - 06:43 PM
Second that Shooter I used Rivnuts as well
#5 stuart bowes
stuart bowes
  • 2,083 posts
Posted 24 March 2023 - 07:56 PM
agree with rivnuts but it's nice bit of engineering I'll give you that
#6 mbolt998
mbolt998
  • 369 posts
Posted 24 March 2023 - 08:06 PM
Rivnuts, never thought of that! I don't own any or the tool. It sounds like they should work though.
#7 nicklouse
  • 18,523 posts
Posted 24 March 2023 - 11:31 PM
Tool not needed. A bolt a nut and some washers is all you need.
#8 Shooter63
Shooter63
  • 1,018 posts
Posted 25 March 2023 - 08:19 AM
Yup that's the way I fit them, it is slow but does the job
Shooter
#9 Clip
Clip
  • 185 posts
Posted 28 March 2023 - 05:05 AM
+1 on the rivnuts. I bought a kit off fleabay for $60 AU and have used it so many times I don’t know how I ever did without. Having the right tool just makes it so fast and easy.
#10 madalicesdad
madalicesdad
  • 30 posts
Posted 28 March 2023 - 07:39 PM
Make it +2. Buy the tool and a few sizes of rivnuts and you'll wonder how you did without them
#11 coopertaz
coopertaz
  • 777 posts
  • Local Club: a-series-magpies
Posted 29 March 2023 - 09:01 AM
if using rivnuts just make sure to grease the bolts and don't overtighten. have them everywhere were i work and people always running them up with a bit in drill and they end up spinning. Then they are a pig.
#12 Tones61
Tones61
  • 428 posts
Posted 29 March 2023 - 11:53 AM
Or just use grille buttons,
10 min job to fit ;-)
#13 bpirie1000
bpirie1000
  • Area Managers
  • 2,337 posts
  • Local Club: Amoc
Posted 29 March 2023 - 12:58 PM
50 year old designs can always be improoved...
Alec was on a budget when he decided to do it that way...
Not stupid if it works.
#14 absx2
absx2
  • 902 posts
Posted 29 March 2023 - 06:33 PM
I`ve been using these for years, just file the hole square and no more seized or cross threaded fixings and no rust.
https://www.ebay.co....pS9XoBWePYZ6A87
Edited by absx2, 29 March 2023 - 06:34 PM.
#15 mbolt998
mbolt998
  • 369 posts
Posted 30 March 2023 - 12:00 PM
The problem is you have to keep taking the grille off to get at things because access is so tight down the front of the engine. If they were just fit-and-forget maybe with some thread-lock they might be OK.
