Door Wiring
8 replies to this topic
#1 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 19 March 2023 - 08:15 PM
O.k. so here is a question for anyone who can assist.
Worked on hundreds of cars and know how each manufacturer gets round the issue.
But with next to naff all space between the door and the pillar...
What does everyone else do.
I have a project on the go and need to run at least 6 wires to each door and obviously do not wish to nip any when the door closes...
Remember fitting central locking from a metro vandem plas back in the day... got to be a 20th century answer.
Any assistance greatfully appreciated...
Thanks....
#2 unburntfuelinthemorning
  • 1,982 posts
Posted 01 April 2023 - 08:41 PM
You used to be able to get something made for the purpose.  It was a tube you ran the wires though and it would be fixed to the A pillar and then slide through a grommet in and out of the door.  They were available from car accessory shops back in the day but don't know if you can still get them.  You could probably make something similar.
#3 Tupers
Tupers
  • 4,143 posts
Posted 01 April 2023 - 08:58 PM
Search on eBay for a “door wiring gaiter” there are loads of different shapes and sizes for different cars.
#4 MiniFanGraham
MiniFanGraham
  • 110 posts
Posted 01 April 2023 - 09:01 PM
this post might help you:
https://www.theminif...res-into-doors/
#5 Ethel
  • 25,919 posts
Posted 01 April 2023 - 11:34 PM
That's what I did. Just 2 grommets & some tubing. Drilled the hole in body a bit smaller so it squeezed that grommet more than the one in the door
#6 nicklouse
  • 18,574 posts
Posted 01 April 2023 - 11:58 PM
Try
https://www.carbuild...g-rubber-sleeve
#7 Chris1275gt
Chris1275gt
  • 938 posts
Posted 02 April 2023 - 09:50 AM
On my W&P 1275 they had drilled 14mm holes parallel from the door through the pillar and what was there was similar to what Ethel has described but had all fallen apart. I couldn’t find a grommet to fit the A post as the metal was too thick, so i shrink wrapped the wires then I threaded that from behind the dash down through the A post and through the hole and into the door. I found the tubing pictured below on eBay which has a 15mm OD. From inside the door and with a smear of silicon lubricant on it (the tube has a spiral profile on it) so then just threaded it over the wires and then threaded it through both holes. It’s a fit snug fit and seals the holes through the door and post. It’s been on 5 years not split or damaged in any way.
#8 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 02 April 2023 - 10:11 AM
Cheers folks. Appereciate all the help..
#9 Jghs83
Jghs83
    Starting My Mini Up
  • 2 posts
Posted 03 April 2023 - 04:38 PM
This is my next mission.
I'm hunting for some "S" grommets to fit in my '99.
