They are standard Smiths gauges but just have stickers on I’ve added (see pics)
The temp sender are part no. GTR101, in the flow for the oil with a DSN filter head.
For the oil temp gauge I wired in 10V from the voltage stabiliser, earth wire to the bracket and sender wire to the other terminal - as instructed.
Whilst doing this I noticed that my coolant gauge in fact wasn’t using a 10V supply I thought it had from the stabiliser, and in fact had a 12V ignition feed, and didn’t even have an earth (no earth through casing as it’s a plastic surround). I guess the sender may be acting as the earth??
Unbeknownst to me I’d had the coolant gauge wired this way for a few years and the gauge was reading very accurately with readings from an IR temp gun helping to show its accuracy (as pic shows), so I thought the voltage stabiliser was doing its job!
Because I knew it shouldn’t be on 12V, I changed it to 10V from the voltage stabliser whilst doing the oil temp gauge.
However, now my coolant gauge reads just above ’C’ when at proper operating temp (88 degrees) and the oil temp gauge reads only at 60 degrees after 30 mins of driving hard which I know is far too low, and show be around 100 degrees ish.
So, Should I wire them both to 12V ignition even though they should be on 10V as I know the coolant gauge was accurate on 12V?
Can anyone explain? Was always told 12V would damage gauges and give higher than true results..
I hope this all makes sense.
