Fitting Rad - Impossible
Best Answer mab01uk , 06 March 2023 - 08:13 AM
I would just remove the square metal cowl from the inner wing. It was deleted from the later Mk3/Mk4 onwards as it make no difference to engine temperature and makes fitting/working on the radiator, etc a whole lot easier. Only reason for keeping it is if originalty is a concern which as you have replaced the original 850 engine with a 1275.....does not seem to be an issue. Also if that was a problem the inner wing cowl is easily refitted during any future restoration to orginal spec.
I wonder why it took BMC/BL so many years to do it?...a cost reduction and it must have made things easier on the production line. Such things are often from a suggestion put forward by someone on the production line but in this case I suppose it also had to be confirmed that removal of the shroud made little or no difference to engine temperatures.
Go to the full post
18 replies to this topic
#16 alpder
alpder
  • 566 posts
  • Local Club: MCR
Posted 07 March 2023 - 09:45 AM
If you want to keep the cowl, you need to use the 2-piece shroud.
Fit the bottom hose and the lower part of the shroud.
Remove the fan.
Position the rad onto the lower mount.
Put a rectangular piece of cardboard against the rad to protect the rad and your hand.
Position the fan and bolt it in place.
Fit the bottom hose onto the pump.
Fit the top part of the shroud, the steady bracket and tighten the fan belt.
Thanks... but I've already taken the shroud out. However, I'm just negotiating on a Mk1 Countryman which would be an as-original resto if I'm brave daft enough to take it on... so your advice might still come in handy.
#17 DeadSquare
DeadSquare
  • 3,382 posts
Posted 08 March 2023 - 07:23 PM
Years ago, I used to slip a hotter cam into friends Minis, and the worst bit was trying to replace the little screw through the join in the 2 cowls at the back.
On my own cars I used to swap the mounts over from top to bottom, so that the larger top "half" was on the bottom and the join was high enough up to see what I was doing.
#18 Spider
  • 15,873 posts
Posted 09 March 2023 - 05:06 AM
The cowlings that I make I do that way. MUCH easier to fit up.
#19 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 10 March 2023 - 06:48 PM
After losing most of my skin on my right arm, I cut off the corner of my bottom two piece cowl around the bottom hose.  Makes getting the rad in and out so much easier!
