Ok, so I've got a decently modified 1275 engine. It's in a Midget - but that aside it's very much in the Mini wheelhouse, so bear with me!
It's been sat since 2020. It ran ok when I parked it up. It wasn't great and needed a tune, but it ran ok.
The problem I'm having is that when I'm trying to start it it gets really slow to turn over. I charged the battery and it did the same, so I tried a spare battery, but it was the same with that. It's since had three batteries and I've tried to jump it off two cars (one of which was a 200tdi Land Rover) and all cases showed the same behaviour.
It spins ok to start with - maybe a little slower than I'd like but ok, then after a few seconds it slows down again. Just gets really slow. I just bought a new battery for it today and it did exactly the same with that one - brand new straight off the rack.
I've had the starter motor out and it spins happily, all functioning as it should.
I've changed the plugs
I've rebuilt the carb (it's getting plenty of fuel)
I did have the distributor out to get to the starter motor and I was fairly certain it went back in the same position (the Midget has two locating bolts so it's easy to get it in the correct position). I thought maybe I'd allowed it to spin 180 degrees out, but I've just tried putting the rotor arm mechanism back in place 180 degrees opposite to where it is and it doesn't seem to want to sit in that position, which leads me to think it went back in the right position.
It has a spark, fuel and air. It should go bang but there is no bang.
I haven't done a compression test on it yet, but that aside has anyone got any suggestions?
My main concern is the starting fast then slowing down. I can't think what would cause that.
