So I'm having an annoying issue where the wire that controls the fuel injector is loose in the ECU connector/plug, and keeps wiggling loose. What's the best way to replace/rebuild this connection?
I've seen that in this thread: https://www.theminif...-plug-connector/ the main ECU plug is this item: https://polevolt.co....U36.html#SID=51
So is my best bet to buy that and just re-terminate each wire and build a new plug?
I'd rather not buy a whole new wiring harness just for this section, and nobody seems to sell a pigtail for just the ECU connector. Car is a 94 SPI with just one plug on the ECU.
Thanks!
