Swapping Flywheel Ring Gear
4 replies to this topic
#1 ac427
ac427
  • 670 posts
Posted 20 February 2023 - 08:21 PM
I watched a video on replacing the ring gear on the flywheel a while back. Should the flywheel be rebalanced after the ring gear is replaced?
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,730 posts
Posted 20 February 2023 - 08:47 PM
Being as the ring gear bows the flywheel when fitted, and change in the fit can cause a change in shape, so technically yes. However in practice it will work without balancing.
When I do mine, the flywheel is in for other work which includes balancing, so all mine are rebalanced anyway. The point is the factory balance is pretty poor in most cases, so having it balanced anyway will make the engine run smooother.
https://youtu.be/ZZeqydn4uFM
Ac
Edited by ACDodd, 20 February 2023 - 08:49 PM.
#3 ac427
ac427
  • 670 posts
Posted 22 February 2023 - 04:34 PM
Ac
Thanks AC.
My engine was built by Swiftune many moons ago. So i was wondering if the flywheel was rebalanced would it also need to be balanced against the crank, as it was when it was first built?
I realise that is a bit over the top but i was wondering from a engineering point of view, what the answer would be?
Edited by ac427, 22 February 2023 - 04:37 PM.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,336 posts
  • Local Club: Amoc
Posted 22 February 2023 - 05:27 PM
What horse power and other mods are you doing?
Why do you wish to change the flywheel?
#5 ac427
ac427
  • 670 posts
Posted 22 February 2023 - 07:18 PM
Just to go from an interia to a pre-engaged starter motor.
Around 100BHP
