Alternative Door Handles
5 replies to this topic
#1 rhidmogz
rhidmogz
  • 21 posts
Posted 18 February 2023 - 09:25 PM
any one done anything different with the exterior door handles??
im sure i saw on here something to do with metro ones?
just wondering if anyone has done somethying like this or completely different?
ive seen a tik tok of a guy shorterning some his corvette handles which looked quite cool and they looked similar to the mini ones thought i might have a go, was just wondering if someone had done anything
#2 nicklouse
  • 18,577 posts
Posted 18 February 2023 - 10:00 PM
The Aussie build cars have ones that look a bit like metro ones.  But yes many have been fitted and they have even been removed.
#3 stuart bowes
stuart bowes
  • 2,103 posts
Posted 18 February 2023 - 10:57 PM
the handle itself is easy,  like any metal work you just cut out the old and weld in the new, obtaining donor metro doors isn't very hard
the awkward bit is that the mini handle is a simplistic design which just presses directly onto the lock mech
whereas the metro (and other) types are a rotating lever which operates via a rod or bar as a linkage
look at page 4 of my build (link below) and you'll see where I got with it. I must stress that isn't a final design yet, I've got the geometry down now but the actual linkages need work in terms of strength and longevity
removal would be very easy, just reskin the door, which is handy because to be honest I'm still in 2 minds about it really
Edited by stuart bowes, 18 February 2023 - 11:57 PM.
#4 mm man
mm man
  • 404 posts
Posted 19 February 2023 - 07:36 PM
I’ve fitted some flush door handles from a Suzuki swift .
I had a complete car  that I was breaking so I cut out  a small section of the door skin including the handles then cut the same out of the mini doors  welded the new ones in job done .
I have photo’s of the job from start to finish but can’t get on with images on here so if you are interested feel free to pm me your email address and I will send them  across  …..feel free to add them to this post if you want .
#5 Ethel
  • 25,919 posts
Posted 19 February 2023 - 11:59 PM
Mini  doors are narrower than your average car's, so it would take a bit of thought
This is true, but there's also the interior release mechanism, though you'd have to avoid the window glass. One that operates via  a cable could offer more flexible options, like the MINI.
#6 stuart bowes
stuart bowes
  • 2,103 posts
Posted 20 February 2023 - 10:21 AM
I was just going to leave that as-is, it connects to a different part of the mechanism on the other side of the window track
but yes somehow doing it by cable could be interesting..
definitely working around the window track is the no1 problem.  if you have old horizontal slidey windows you're laughing
Edited by stuart bowes, 20 February 2023 - 10:21 AM.
