O2 Sensor Reading Steady High 840Mv
Best Answer madazv8 , 26 May 2023 - 03:25 PM
So an update on this saga. Car is running much better, but I would say still not perfect as reasons below...
After doing everything I could and still not getting to the bottom of this issue, I finally folded and admitted defeat and took the car to the mini specialist.  This was after replacing the MAP sensor I wasted as per above and on my other thread about replacing it.  It has been an interesting journey of learning and a few times could have led me down some crazy dead ends.
In summary,  the car would not idle well.  It was clear visually that it was throwing excessive fuel down the intake at idle.  Lambda was reading constant high, never went closed loop, and as a result it would only run in limp mode with bugger all power.
So.  A day after dropping the car off I get a TXT message with good news.  Car is running better.
A spare ECU was plugged in,  no change.  ECU ruled out.
Confirmed no vacuum leaks.  I had gone over this countless times,  and was confident that was the case.
Checked fuel pressure.  Spot on.
Measured valve lift with a dial gauge.  Seems somebody has fitted a high lift CAM ! We know the SPI doesn't like that ! and most likely why I have high MAP reading.
Un-plugged the coolant temp sensor and connected an original Rover item which he had on the shelf.
Place said coolant sensor in a mug of boiled water - immediate difference ! Car idles.
Frustratingly I had ruled out the coolant sensor as it was new, and it also seemed to be working according to MEMS apps.  The mechanic has had experience with recent replacement coolant sensors being bad.  Even though the readings on the MEMS apps seemed to look realistic,  somehow it does not marry up to the ECU.  My MAP reading is still too high,  and the car bogs a bit at mid range under hard throttle, but that is because of this camshaft.  I'll live with that for now.
So lessons learned:
When everything you read says the coolant temp sensor has the biggest effect.  Challenge your assumption that yours is ok. Especially if it is a replacement.
The Vacuum gauge  diagnosis I talked about earlier in this thread could have had me looking at CAM timing and valve guides etc.  These are written for carby engines.  Beware.
Don't pull stupid amount of vacuum on your MAP sensor,  expensive mistake.
Anyway,  It has been an education.  Thanks to all who took the time to offer wisdom.   I'm off for a 500km drive this weekend :)
Go to the full post
55 replies to this topic
#31 sonscar
sonscar
  • 2,997 posts
Posted 28 February 2023 - 05:31 PM
In my experience with EFI everyone blames the sensors or ECU and almost ignores the fact that it is an elderly petrol engine with all of the maladies they have always had.If one cylinder was excessively rich and all the other lean it could go two ways,,either always add fuel or always subtract fuel as the lambda reads the average of them all.I would possibly concentrate on the lean cylinders.Steve..
#32 madazv8
madazv8
  • 119 posts
Posted 06 March 2023 - 11:51 AM
Hi,
An update on this saga. So I managed to replace the O2 sensor with the real Bosch item.  Got everything together and fired it up.  Sadly things were worse  - as per my post about seating the intake. By worse I mean -  MAP readings too high,  higher than the borderline previously.  Lambda 1000mv steady.
Couple of reasons for this which could be my own doing....
 - I didn't fully remove the intake (trying to avoid dropping coolant as I work in an apartment complex garage).
 - I didn't remove and replace the gasket (yeah yeah  I know).
So,  tonight I stripped down the intake properly to inspect everything, and fit a new gasket.  Here is what I found.
  • The alignment ring from the port between 4&3 was not there. Other one was.
  • The flange where the alignment ring is missing was scored up,  and seems to have a circular indentation as is somebody has tried to tighten the manifold with the ring dislodged.
  • Found the missing alignment ring between the head and exhaust manifold
So my current theory is I have has an un-metered air leak.  but this wouldn't explain the high MAP level - or would it ?
Thankfully I was given a spare intake which I will swap over soon.
p.s. What side does the textured face of the gasket go to? asking for a friend.
Edited by madazv8, 06 March 2023 - 12:09 PM.
#33 sonscar
sonscar
  • 2,997 posts
Posted 06 March 2023 - 02:57 PM
Atmospheric pressure is high map.If the engine is sucking air after it the manifold would be at closer to atmospheric than it normally would giving rise to commanding more fuel.As I always understood it.Steve..
#34 genpop
genpop
  • 508 posts
Posted 06 March 2023 - 04:34 PM
Slightly open the rings so they stay in place when you press them in their seats.Put the new gasket on so you can read the texture.When you put the manifold on have a look that there is no gap. Now put on the brackets and nuts. Everything will become good!
#35 madazv8
madazv8
  • 119 posts
Posted 11 March 2023 - 10:26 AM
Hi all,
So today I got some time and put the mini back together.  Unfortunately the problem persists which is a little frustrating, I was hopeful I was on a good path.  Seems not.  Not sure where I'm going now. Here is what I have done...
  • Swapped over the inlet manifold for one with clean faces. New gaskets on the injection unit.
  • Made sure alignment rings were in place correctly.
  • New exhaust / inlet manifold gasket - metal face towards the manifolds as per guidance on minispares website.
  • smear of high temp silicone on inlet manifold faces just to be sure.
  • Replaced a cracked breather hose (think I split it trying to wrestle it off during strip down).
  • Triple checked all other hoses and fuel trap.
  • Adjusted the throttle cable as per the manual.
All sensors are new and working.  O2 sensor is new Bosch unit.  Symptoms are the same.  Bad/low idle speed. Lambda reading max voltage. No power.  No closed loop. Sprayed half a can of cold start on every gasket face and vacuum hose,  no obvious leak detected.
Connected memsfcr and the log looks the same. Attached anyway.   Tried to get memsrosco working,  but it wouldn't connect to the ECU.
Observation:  If I pinch or remove the vacuum line to the ECU when the car is running,  the engine does not react in any way.  The MAP does drop down when I rev the motor,  and it does drop from atmosphere when I start the motor.
Observation #2.  Stepper counts seemed very high after assembly.  They were normal prior to this.
Could cam timing be an issue,  but surely that doesn't explain the above?
Suggestions begged for, and welcome.  Thanks folks.
Edited by madazv8, 11 March 2023 - 12:27 PM.
#36 madazv8
madazv8
  • 119 posts
Posted 12 March 2023 - 06:30 AM
Clutching at straws,  but I know the car had a cam chain recently.... I sit at a steady 12 inches mercury,  which is not a good vacuum.
#37 genpop
genpop
  • 508 posts
Posted 12 March 2023 - 01:14 PM
on the bulk head nearby the inertia switch there are two relais.One is for the electric fan, the other for the lambda heating.Check if there is coming out current to the lambda probe. There should be 12 V between the black and the slate cable at the lambda probe.If not lambda probe will not work.In your mems-rosco directory there is a engl.pdf file read that .You havent set the com port!
According tou your picture  and what you say, the timing chain could be a teeth back!
#38 MatthewsDad
MatthewsDad
  • 812 posts
Posted 12 March 2023 - 01:46 PM
I'm working through a similar problem at the moment, but you're ahead of me. I'm impressed by your patience and how methodical you've been (and the advice you've received!), good luck.
#39 madazv8
madazv8
  • 119 posts
Posted 12 March 2023 - 11:43 PM
Yep I did that,  still does not connect :(
#40 genpop
genpop
  • 508 posts
Posted 13 March 2023 - 06:31 AM
what interface do you have? Some arduino
 usb-ttl converters work with 3V, they do not work, you need a 5V one.Some nameless as well. I prefer the one in the pdf. Always publish the csv file, you may read it with the standalone memsfcr and you can easyly change it in excel for your needs..fcr files you may read only in the web based version!
#41 madazv8
madazv8
  • 119 posts
Posted 13 March 2023 - 07:39 AM
I think I understood about none of that :(  Your advice is appreciated,  sadly I am not enough computer literate to understand what you are recommending.
Edited by madazv8, 13 March 2023 - 07:41 AM.
#42 madazv8
madazv8
  • 119 posts
Posted 13 March 2023 - 07:49 AM
I will check that,  thanks.
EDIT:  12V feed confirmed.
Edited by madazv8, 08 April 2023 - 10:36 AM.
#43 madazv8
madazv8
  • 119 posts
Posted 05 April 2023 - 12:00 PM
Still working through this issue,  been a while as I was busy with work.
Had a mate come over to sanity check what I think I am seeing. Results from todays play around are:
Noticed the fuel spray into the throttle body is very heavy,  the flap looks soaking wet,  is this normal ? The injector does pulse at times, but does not look like a fine mist cone.
Tried an injector from a spare throttle body,  but it is different in appearance !? even though it is same shape.  Leaked badly out the top seal so couldn't test it. According to google it is a Renault Clio SPI injector ! Is this a mod ?
Pulled the vacuum hose off the air cleaner,  and left it open,  car idles much better.  O2 sensor danced around a couple of times but then reverted to max voltage.
Squeezed fuel pipe to make car stumble,  no response from O2.
Rigged up a syringe to the MAP sensor, along with a gauge, and pulled a more correct vacuum.  ECU cuts the fuel completely and car stalls.
Images - Clio injector on the right.
Edited by madazv8, 05 April 2023 - 12:01 PM.
#44 madazv8
madazv8
  • 119 posts
Posted 16 April 2023 - 10:29 AM
OK, so this is escalating every time...  this weekend I decided to check the low vacuum reading with another gauge just to be sure before I started digging into cam timing. I am absolutely certain there is no vacuum leak, I have checked everything, countless times.
Glad I did this as it seems the cheap e-bay gauge I was using has too much dampening inbuilt.  When I connected a more expensive gauge I got some new information.  Instead of a steady low reading which the e-bay gauge was indicating, the new  gauge was rapidly dancing around between 13-16 inHg.  Still low,  but an important distinction. I am inclined to believe the new gauge as it was fairly pricey and sold by a major auto store.
The dancing needle smooths out after I give it some RMP and the needle also behaves as it should with throttle blips.  So according to numerous online diagnostics guides,  a dancing needle like this means some issue with the valvetrain.  The movement is to rapid for it to be a single sticky valve, which then points to worn valve guides. This is cited in various websites.  Before I venture into a head off job,  would like some opinions please.  The trouble I have with this diagnosis is that I do not get any smoke at all on cold start up - but surely with  worn valve guides I would expect smoke on start up as oil seeps down?  Can the guides be worn and I don't get smoke ?  What do people think?
p.s. I changed the o-ring on the Renault Clio injector mentioned in the last post.  It runs exactly the same as the mini injector (stationary anyway).  And they seem to be available on e-bay from unknown sources.
#45 sonscar
sonscar
  • 2,997 posts
Posted 16 April 2023 - 12:50 PM
I associate fluctuating vacuum readings with burned or poorly seating valves.Might be wrong.As I said earlier EFI faults are often a sickening motor.Steve..
