Sticking Distributor Relubrication
10 replies to this topic
#1 ac427
ac427
  • 674 posts
Posted 14 February 2023 - 01:32 PM
My 59D distributor mechanical advance mechanism has dried out.
I need to disassemble and relube it.
Are there any official or recommend types of lubricant that should be used?
#2 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 14 February 2023 - 01:36 PM
I have always just used a little engine oil, make sure you keep it to a minimum as you don't want it getting on the points
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,343 posts
  • Local Club: Amoc
Posted 14 February 2023 - 04:46 PM
Good point....
#4 nicklouse
  • 18,574 posts
Posted 14 February 2023 - 05:36 PM
Good point....
But as the bob weights are hidden away it would be very hard for any lube to get up to the points.
but I would not use engine oil. Just strip and clean everything up and use some light oil.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,741 posts
Posted 14 February 2023 - 06:02 PM
Easiest option is to
Have it serviced and received £95,
Ac
#6 Shooter63
Shooter63
  • 1,024 posts
Posted 14 February 2023 - 06:07 PM
Ac
I presume you mean recurved?
Shooter
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,741 posts
Posted 14 February 2023 - 06:12 PM
Yes sorry typo,
Ac
#8 Shooter63
Shooter63
  • 1,024 posts
Posted 14 February 2023 - 06:34 PM
Yes sorry typo,
Ac
OK do you want a PM on here or FB
Shooter
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,741 posts
Posted 14 February 2023 - 07:47 PM
Either is fine.
Ac
#10 sonscar
sonscar
  • 2,995 posts
Posted 14 February 2023 - 08:34 PM
I put oil onto the screw at the top of the shaft also,Steve..
#11 ac427
ac427
  • 674 posts
Posted 15 February 2023 - 12:52 PM
Apologies for the misleading thread title. It is more to do with the what the advance mechanism pivots on, rather than the mechanism itself.
I believe my problems are because the oil has dried out over several years of storage. So there is mechanical resistance between the two shafts
Although obviously regular oiling of the pad under the rotor arm would have avoided my current situation. I thought perhaps something more synthetic/newer/PTFE would be better than just some normal engine oil?
