So are you saying that your NOS 21A1889 pins do have the welded on washer?
I've tried fitting one of the arms with one of my original (washer welded on) pins this morning using new standard Mini Spares Centre tapered rubber bushes and it all went together ok. The inside flat of the washer sits almost against the subframe, probably in contact around the back. My concern now is that when the nut is tightened the arm moves by slippping against the rubber.
I was under the impression that the rubber should grip the inner surface of the arm and the metal tube inserts inside the bushes should also not turn on the pin and that all movement would be be accommodated by the bending/twisting of the rubber itself. Am I wrong in this assumption? It seems to me that the tube inside and the pin don't make a bearing of any sort and if the arm slips on the rubber it will just cause friction which will mean it would soon fail.
I'm wondering if the washer is prventing the bushes being squeezed enough to lock them solid?
Any thoughts on all this?
Edited by minstix, 13 February 2023 - 10:14 AM.
