Elf Again
elf
2 replies to this topic
#1 toromod
toromod
  • 43 posts
Posted 30 January 2023 - 01:12 AM
Before and after views of the front grill after polishing with fine wire wool and "Peek" metal polish - the slats came up really well too. Good job for a wet and windy day, Chuffed!
Attached File  20230202_234227~2.jpg   38.86K   2 downloads[attfachment=218012:20230202_112145~4.jpg]
Edited by toromod, 03 February 2023 - 12:48 AM.
#2 toromod
toromod
  • 43 posts
Posted 08 February 2023 - 10:16 PM
During the restoration the upper area of the wheel arch where the air vent hoses attach needed work. During this I became aware that although this awkwardly shaped section closes off the area at the top of the wheel arch, it is still open into the engine bay, so any moisture getting into the engine bay will get into this "well" at the top of the wheel arch, where I'm sure it will eventually rust and rot through. So why the gap at the top of the inner wing under the scuttle panel on each side? Easy enough to deal with when refitting wings but a real pain in the ### when doing repair work?Attached File  20230124_165944~2.jpg   49.13K   0 downloads
The gap is in the dark recess behind the hydrolastic hose.
#3 toromod
toromod
  • 43 posts
Posted 09 February 2023 - 12:33 AM
There is a small gusset plate that goes between the A-panel and the inner wing, at the top of the wheel arch, it is part no.14A8348 (Somerford) but even fitting that at the top of the wheel arch is an awkward B! Anybody else have any thoughts on the gap? Or sealed it?
